Fire breathing EVO 8 20psi launch control & No Lift Shift
Old Jan 10, 2016 | 11:34 AM
tunermt's Avatar
Here is an EVO 8 I just did for a guy in Central America running a big laggy forward facing turbo on his bone stock 2.0L 4g63. Using Antilag launch control this car make 20psi on the line and holds boost between shifts with No Lift Shift.
Pictures and nice little write up on NLS and launch control tuning: https://brewedmotorsports.com/no-lif...aunch-control/
Drag style Antilag Launch control Video:
Video of the NLS in action (stock engine bolt on forward facing Precision turbo kit 21 psi):
Old Feb 7, 2016 | 03:11 PM
tunermt's Avatar
Anybody else running a no lift to shift setup? Post up your pics and vids
Old Feb 18, 2016 | 09:15 PM
KMA91's Avatar
Looks intense. Haha
Old Feb 21, 2016 | 01:39 PM
psi-01's Avatar
What settings did u use for the two-step if u dont mind me asking. Building 20psi on the line is awesome!
Old Feb 28, 2016 | 06:22 PM
SmurfZilla's Avatar
crazy
Old Mar 4, 2016 | 08:36 PM
tunermt's Avatar
Honestly the settings/tuning really depends on the build, i would never simply upload these settings into another ECU and test. Def need to start on the conservative side and work your way up to the boost you want all while keeping a close eye on EGT/lambda and engine noise from the knock sensor/s.
Old Mar 9, 2016 | 04:57 PM
desiromeo812's Avatar
Keep in mind OP is not in US. he probably has anti lag from the factory.
Old Sep 7, 2016 | 10:35 AM
tunermt's Avatar
Sorry for the delay, no this car actually has no factory anti lag hardware everything you see is just through the tuning. (stock intake manifold/long block, just bolt on forward facing turbo kit)
Old Mar 15, 2017 | 12:34 PM
tunermt's Avatar
This car recently got a make over, owner removed a good amount of weight from the car and will be running a built 2.0L engine very soon. Looking forward to re tuning this thing with the new engine.
Old Mar 17, 2017 | 11:32 AM
CrazyK's Avatar
Old Jul 15, 2017 | 09:03 PM
tunermt's Avatar
boosting I like the dual dump tubes out each side of the vent like that has a nice horn look to it.
Old Jul 15, 2017 | 09:16 PM
evo.matt's Avatar
Originally Posted by CrazyK
that was badass
yellowevo82
Mar 31, 2009 01:38 PM
scout35316
Feb 15, 2009 05:43 PM
midwestmonster
22
Nov 17, 2005 06:43 AM
EvolvedfromaWRX
19
Aug 6, 2004 09:10 AM
