Sponsored by:
Sponsored by: CARiD
Launch control ,and flat foot shift??
Old Feb 11, 2009 | 03:32 PM
scout35316's Avatar
Launch control ,and flat foot shift........are there any easy options to add this feature to the evo x?? If there are what might they be and where could one procure one of these beauties?
Note: I do know this was an option on one model,just not the one i am working on..........
Old Feb 11, 2009 | 05:45 PM
TheBlueBlur's Avatar
The MR comes with both of these features.
Old Feb 12, 2009 | 01:57 AM
scout35316's Avatar
did you not read the simple note at the bottom of my post?
Old Feb 12, 2009 | 05:53 AM
burnings's Avatar
All evo X comes with launch control.
Old Feb 12, 2009 | 07:53 AM
WTFchuck's Avatar
how to enable? currently at work and left my owners manuel at home... i have the 5 spd
Old Feb 12, 2009 | 08:54 AM
linjy2's Avatar
press asc off once, clutch in, foot on gas, rpm goes to a steady 5500. release clutch, insane launch!
thats the basic concept, practice is required or you will burn the clutch.
Old Feb 12, 2009 | 09:06 AM
scout35316's Avatar
If this in fact is the case can you change the launch RPM , and if so how?
Old Feb 12, 2009 | 09:50 AM
linjy2's Avatar
u need a tune to change it, ecutek, cobb ap, ecuflash.
i have mine changed for both launch and redline.
Old Feb 12, 2009 | 02:28 PM
scout35316's Avatar
Thank you , talked to Perrin today and they said the same thing. Pretty much the stock launch is set a bit high ,and that we can alter it with the Cobb tuning port,so thats cool ,what about flat foot shifting or WOT shifting?
Old Feb 12, 2009 | 02:55 PM
flyboytb's Avatar
I was also wondering about WOT shifting, this is a feature I miss about my SRT-4.
Old Feb 12, 2009 | 07:46 PM
Jblade's Avatar
I asked Robb@COBB Tuning about no-lift/flat foot shifting and if I'd be a tunable feature in AccessTuner Race, and he said "not currently but it may be something they consider in the future". I suggest that people start putting in the request for it so they know it's in demand!
Old Feb 13, 2009 | 11:38 AM
scheides's Avatar
EvoM Moderator
We've had NLTS for the Evo 8/9 for a long time now, I'm sure it won't be too long before you X guys can have it too
Old Feb 14, 2009 | 07:35 AM
ZLAYER's Avatar
The problem with this statement is that you need to practice an act that needs to be performed perfectly (even the first time). From all Ive read, you start the process then when the rpms set, you let out slightly on the clutch, letting the car roll forward just a bit then quickly let out (not too fast, not too slow). I havent tried it cause I dont want to buy a new clutch. But I did do the first part (let the rpms set) then let out on clutch just a bit to slightly move forward, and instantly the cabin filled with the foulest of odors. My Z was so much easier to launch!
Old Feb 14, 2009 | 07:43 AM
stiftwevo's Avatar
isn't launch control really bad for the motor?
Old Feb 14, 2009 | 09:09 AM
linjy2's Avatar
u held it to long then. it seems like i just drop it.
no idea...everything is bad for the car if we drive it hard. probably hurts the transmission more then the motor.
