RPF1 Sizing, Track Day
Old Dec 10, 2019 | 07:25 AM
Zer0_13's Avatar
Alright. I have been hunting and searching for a while and just cannot find what I am looking for.
I am currently building a competition car, mostly hillclimb and track day. it is a 2005. Any street use I would jsut swap back to my OEM wheels/tires. So, what I am trying to do is stuff as much tire under the car without having to cut or do really serious surgery, rolling fenders im totally fine with, the rest I am sure can be done, but less is more and all that.
I am debating a set of 18x9.5 or 18x10 RPF1s +38 offset, and use spacers as needed.
Now, I see a bunch of stuff on 18x10.5 but not much on 18x10, I wanted to see if something 10 wide can actually fit. The plan is currently if its a 9.5 I'll run 275 Hoosier A7s. if its 10" I can step up to more like a 295, I just need to see what I can fit.
I am running Ohlin's coilovers right now with adjustable camber plates up front so I can tune in as much camber as would be needed.
So, if people can possibly weigh in how doable this particular set up would be I would greatly appreciate it. Thank you very much in advance.
Old Dec 10, 2019 | 07:56 AM
Dallas J's Avatar
Veteran: Army
Hoosiers want more wheel, almost no point in running at the low end of wheel for any given tire spec since the tire will be sharper with a stronger outer edge (evos like to kill the outside front on most cars). So a 285 and 295 (theyre basically the same width, 295 is just taller) id recommend a 10.5" wheel. Just that 1/2" from a 10 to 10.5 is significant.
Caveat here is its not easy to fit. Check out Driv200 thread in the motorsport section about him trying to get 295 and 10.5s fitting.
Old Dec 10, 2019 | 08:09 AM
Zer0_13's Avatar
thank you for the heads up there. That does look to be a touch more than I want to head into at the moment. Once the driver mod far exceeds the cars capability, I may see about a big offset, and then just cutting and flaring if needed. So, it seems like it might be better to just stay on the 9.5" widths.
Old Dec 10, 2019 | 08:28 AM
Dallas J's Avatar
Veteran: Army
I would say an RPF1 18x10 and like a 265-275 RE71 or Rival would be a perfect tire to build up the driver mod on.
Old Mar 12, 2020 | 01:08 PM
Zer0_13's Avatar
Alright, I took your advice, I went to an 18 x 10 +38. Place I diverged a bit is I got a set of 275 R1S and A7 scuffs off of a local time attack guy. I will be running a 20mm spacer up front and a 5mm in the rear, both slip on hub-centric. I assume a roll and possibly a fender mod will be in my future. I just want to see the difference in grip I get going to to R-comp after racing for the last decade on 200TW streets.
GTABurnout
Jan 12, 2019 11:50 AM
XcreatonX
Jan 6, 2012 09:37 AM
metalsaber
Jan 1, 2011 04:08 PM
westmc
17
Apr 5, 2010 07:26 AM
ultradef
19
Feb 15, 2009 05:24 PM
