Bunch of Stereo Install Questions
Old Apr 16, 2004 | 09:28 AM
highvoltz's Avatar
Thanks for the pics, those will help out alot.
What's it take to pull up the moulding to run the wires? any tricks / problems I'll run into?
Old Apr 16, 2004 | 04:33 PM
highvoltz's Avatar
where do you ground the head unit? I cant really get to any of the screw locations that are very visible..
Old Apr 16, 2004 | 06:01 PM
highvoltz's Avatar
grounded below on the left of the console.. seems to work good.
The head unit is 60max x 4. 27watts rms. I cranked up the bass on the head unit, and cranked it... the internal dome light started to dim.. This doesnt seem right. Why might it be dimming?
Old Apr 16, 2004 | 06:08 PM
jaymz916's Avatar
If your car was off, but key turned to on, that's why your dome lights dimmed, your battery can't handle the load, if the car was running, and the lights still dimmed you need a cap. Best to run high audio with the car running, then the alternator cranking out juice, with it off, you're just killing the battery. Remember, the batterie's only and sole purpose is to just start the car.
Old Apr 16, 2004 | 06:22 PM
highvoltz's Avatar
OK. Car on, they still dim. It's only the internal lights. The headlights do not dim AT ALL. Are other people having this problem??
Old Apr 16, 2004 | 06:26 PM
jaymz916's Avatar
You still need a cap, takes a huge load off the alternator, for every 500 watts of power you need 1/2 Farad. So if you're pushing 1000watts, you should get a 1 farad cap.
Old Apr 16, 2004 | 06:28 PM
highvoltz's Avatar
this light dimming is from just the head unit. there is no amp/sub hooked up as of yet.
Old Apr 16, 2004 | 06:41 PM
jaymz916's Avatar
that's odd, did you use a harness adaptor, or did you just tap power off a 12v line? Are you sure you've got your 12v switched, and 12v constants hooked up right?
Old Apr 16, 2004 | 06:45 PM
highvoltz's Avatar
i bought a harness for a mitsubishi 1992 +
Old Apr 16, 2004 | 06:51 PM
jaymz916's Avatar
Okay, so you went yellow to yellow, and red to right, right?
Old Apr 17, 2004 | 08:37 AM
highvoltz's Avatar
yup, I tripple checked all the wires to make sure they went to the right place
Old Apr 20, 2004 | 10:50 AM
GrimDog's Avatar
is your dash dim? if so check out your back right tail light, you might have blown a fuse. The stock radio has a dimmer wire to connect. If you connected it, or it tapped something you will blow the fuse.
Old Apr 20, 2004 | 11:25 AM
highvoltz's Avatar
I did not use the dimmer, the antenna, and one other one, I forget what it was (at work right now, dont have the book with me)
the dash is fine, everything works great. It's just when I crank up the head unit, the over head dome light that dims.
jrainwater
27
Jul 15, 2017 03:21 AM
just a neon
Jul 11, 2015 03:51 PM
DynoTechnik
Nov 17, 2010 08:11 AM
ch1215g
13
Mar 13, 2010 10:15 AM
CoronaLancer
Apr 29, 2004 07:49 PM
