Shaking steering wheel problem.
Old Mar 9, 2010, 04:48 AM
  #31
dvd_mi's Avatar
Wheels are balanced (I even used two different sets). Rotors are OK (no problems while braking). This does not happen on the turns (cornering), but usually after the turn on the straight.
Old Mar 9, 2010, 08:46 PM
  #32
WRC-LVR's Avatar
It is pad transfer....as you said it happens AFTER the turn. the rotor cleans itself off during the following straightaway. There has been a ton of threads in the past about transfer layer causing this.
proper re-bedding before the event helps a bit. different pads sometimes helps.
Old Mar 9, 2010, 10:48 PM
  #33
amsevokid's Avatar
u need an alighnment
Old Mar 10, 2010, 05:28 AM
  #34
Bassicfun's Avatar
Is there a reason you aren't replacing or commenting on the tie rod question? I have this same issue with mine just developed, a "9 & 3" shake showed it is just one outer tie rod end, $15 for a lifetime warranty one at the local autoparts store...
Old Mar 11, 2010, 04:57 AM
  #35
dvd_mi's Avatar
I'll have to check those tie rods. How much they cost???Where did you buy them. What local auto parts store???
Old Mar 11, 2010, 08:26 AM
  #36
Bassicfun's Avatar
Local parts stores ALL had the wrong info for the evo... MSRP from a dealer on these is $40.93... maybe hit up RussellM here.
Old Mar 11, 2010, 11:25 AM
  #37
mr. happy's Avatar
I know you're not in cbus that often, but the local ricart dealership seems to have a lot of parts in stock.
Old Mar 12, 2010, 05:43 AM
  #38
Bassicfun's Avatar
Was in town last night actually... Ricart out of stock on this, Dennis Auto in stock... will be replacing & realigning it at home tonight.
Old Mar 12, 2010, 07:20 AM
  #39
evremonde's Avatar
So the tie rod(s) was the culprit?
I think my car may be developing these symptoms
Old Mar 15, 2010, 09:35 AM
  #40
MrHouse's Avatar
Must be the tie rod
idiaroi
Jun 8, 2016 07:27 PM
Evo47
Mar 11, 2016 12:02 PM
idiaroi
Aug 27, 2015 09:02 PM
beasters
24
Nov 9, 2013 12:50 PM
qu evox
20
Apr 16, 2009 10:58 AM
Quick Reply: Shaking steering wheel problem.
