Rear roll center correction vs standard bushing for dd
Old Jun 27, 2017, 10:43 PM
asu11's Avatar
Car is 90% dd with some light track duty.
Should I opt for the rear roll center kit or just the standard bushing upgrade?
I still want to be able to dial toe to zero so not sure if the kit will cause any issues during alignment.
Car is on FA500 coilovers and has a 24mm rear whiteline sway bar.
Thanks
Old Jun 28, 2017, 05:12 AM
Roen's Avatar
Link to kit?
Old Jun 28, 2017, 06:38 AM
Received 1,384 Likes on 1,317 Posts
Are you referring to the bump steer correction kit ? (KCA388
Rear Steering - bump steer correction kit)
Not familiar w/the WL rear roll center kit?
BTW, we run a similar set-up. I run the FA510's w/the WL 24mm bar & the rear bump steer bushing
Old Jun 29, 2017, 07:30 AM
DSMolition's Avatar
I don't think there would be an issue as there is not for the front.
Old Jun 30, 2017, 02:03 AM
asu11's Avatar
Yeah sorry I meant the rear bump steer kit not roll center
https://whitelineperformance.com/mit...bushing-kca388
Was just wondering if its worth installing on a DD.
Old Jun 30, 2017, 05:04 AM
I run the kit as noted, but for DD you will not feel any diff. Its more of a high level bushing & meant for track work IMHO
Old Jun 30, 2017, 05:12 AM
asu11's Avatar
Yeah that's what I figured. I guess i'll just go with the standard bushing upgrade for now and if I feel the need in the future I'll get the offset kit.
Thanks
Old Jun 30, 2017, 06:37 AM
kyoo's Avatar
if you do light track work and you're in there you might as well. no nvh difference, no issues in alignment, etc.
IIRC the four bushings evo 8/9s need to correct suspension geometry are
front control arm bushings
rear trailing arm bushings
roll center adjuster
bump steer kit
Old Jun 30, 2017, 07:39 PM
asu11's Avatar
Yeah I guess I might as well then. Thanks for the input.
RussellM
Evo 'For Sale' Suspension / Brakes / Handling
13
May 20, 2014 03:18 PM
RussellM
EvoX 'For Sale' Suspension / Brakes / Handling
Apr 8, 2014 10:44 AM
RussellM
MitsubishiParts.net - WA
Mar 12, 2014 03:13 PM
19psi
14
Jul 6, 2011 07:44 AM
belizelittle39439
55
Jan 28, 2011 10:15 AM
Quick Reply: Rear roll center correction vs standard bushing for dd
