Alignment and Steering Question.....
Old Oct 2, 2004 | 05:59 PM
RSGuy's Avatar
Hey guys,
A while back I had hit a curb and had to get an alignment and tires. I took it to the dealer to get aligned. Later I noticed that to get the car to track straight, the steering wheel must be turned to the left slightly. In other words, the steering wheel isn't "centered" perfectly. The tech who did the alignment said it wasn't a big deal but I've come to the point where I can't stand it anymore. I'm very **** about my car and it just ruins the feel for me. I just wish I could get the steering wheel all centered up perfect like the day I got it. Has anybody else had this problem before? Can I fix it? Should I stop being so **** about my car? Please help!!!!!! Any advice is appreciated. Thanks
Fred
Old Oct 2, 2004 | 06:04 PM
AUSS1E's Avatar
you can always take the steering wheel off and recenter it. Not too sure about how to do it with airbags so it may be best to have your dealer do it
Old Oct 2, 2004 | 07:05 PM
Evolboost's Avatar
I know how you feel. I am pretty **** about the alignment as well. If it's not going straight when I take my hands off the wheel it's not good enough.
Perhaps you could ask him for the spec sheet from the alignment. They could have messed up and just "forgot" to tell you since they are lazy.
Old Oct 2, 2004 | 07:24 PM
93h22cvc's Avatar
if it bothers you that much you can also lower the sub frame ,lower the steering shaft,and move the steering shaft 1 tooth.that should fix your problem. have you had an aftermarket clutch installed. cause some geniouses in the begining were dropping sub frames to install clutches. maybe mis alligned
Old Oct 2, 2004 | 07:32 PM
Nad1370's Avatar
Why go thru all this^^^
You paid to get your alignment done right. If your not happy...bring it back so they can fix it right the way you want it.
Old Oct 2, 2004 | 07:39 PM
WildRice's Avatar
This is simple to adjust, take it back and make them do it for you or take it to another shop and have it done there. The tech was sloppy.
06RedRalli
Apr 21, 2016 02:54 PM
Clipse3GT
12
Jul 25, 2009 01:26 AM
dek0026
May 15, 2008 03:31 AM
Chewie4299
Jan 19, 2006 10:40 PM
RSGuy
Oct 3, 2004 01:44 AM
