Wheels that fit WITHOUT Spacers?
Old Feb 3, 2005 | 07:19 PM
wingnut's Avatar
This information is available across tons of threads but I think it'd be nice to have it collected in one spot. Post any wheels that fit without spacers, fender rolling, or other modifications to a bone stock EVO.
Old Feb 3, 2005 | 09:49 PM
bolio's Avatar
I know the 5zigen FN01R-C fit w/out spacers. And I saw on this forum someone running Mustang Cobra wheels that fit perfect, looked good and cost $110 a piece.
Old Feb 4, 2005 | 07:05 AM
Neal@tirerack's Avatar
BBS
RE 18x8.0
Kosei
K1-TS 17x8.0
Mille Miglia
HT3 17x8.0
OZ
Superleggera 18x9.0
Speed Star Wheel
SP1 17x8.5, 18x8.5 only
SSR
Comp-H 17x8.5
Competition 17x8.5, 18x8.5
GT2 17x8.5, 18x8.5 with 35mm offset only. 18x8.5 42mm offset has spacer
GT7 18x8.5
Old Feb 4, 2005 | 02:39 PM
Kayaalp's Avatar
The Mustang thing just won't work. The offset and bolt-pattern work, but the center bore of the Mustang is a bigger diameter. So, the wheel might fit, but it won't be hub-centric anymore. It's just a matter of time before your lug studs snap and you find yourself without a wheel.
Emre
Old Feb 5, 2005 | 07:37 AM
ACM's Avatar
ACM
Emre
This is simply not the case. Most 'generic' wheels are adapted to specific hub fitments via the use of plastic rings that clip into the wheel's centre bore. These rings have the structural integrity of Linguini - if your statement were accurate half the aftermarket wheeled cars on the road would be missing one or more wheels. Load transmission is achieved by the clamping force of the lug nuts, centering the wheel is achieved by the use of concal seat nuts.
Charles
Old Feb 5, 2005 | 07:41 AM
hkfeet's Avatar
z1auto has wheels on their site that fits the evo. Might be helpful to you.
Old Feb 5, 2005 | 08:48 AM
Z1 Performance's Avatar
wingnut - look for one of us online this weekend on AIM (z1auto) - can give you the skinny on everything we offer that fits. Our wheel section on our site has all confirmed fitments as well, though not everything we offer is on there
adam
Old Feb 5, 2005 | 10:24 AM
Charles
Well somewhat... If wheel manufactures had to make wheels for every hub diameter/seat of every car it would cost WAY too much. So they make a common fitment that can also accept hubcentric rings. Differ sized rings will allow the wheel to fit a boarder range of vehicles. Many of the rings are plastic, but many also offer the same ring but made from aluminum. The aluminum rings help fight warping from rotor heat.
Lug nuts/lug bolts do not center a wheel to the vehicle. If that were the case there would be no use for hubcentric rings. They don't call them hubcentric lugs because that's not their job. When you don't use the ring (when required) the wheel will actually sag on the hub and rest on the studs. The nuts will then tighten down the wheel in the same way its sitting on the hub. It may not be visually noticeable, it its being bolted down crooked. This will then cause a vibration while you drive down the road. When you use the ring the wheel is being suspended tightly on the hub. The hubcentric ring is keeping it... well hubcentric.
90% of the calls I get from people saying they have vibration, bad tire, bent wheel etc etc after we sent them a pack haven't used the required centering ring, but instead relied on the lugs to center the wheel. Once they install the ring the vibration goes away and all is good.
Old Feb 23, 2005 | 02:16 PM
Overload's Avatar
Originally Posted by Neal@tirerack.
.... When you use the ring the wheel is being suspended tightly on the hub. The hubcentric ring is keeping it... well hubcentric.
Neal,
is there anything I can buy that would allow me to correctly mount the Cobra rims? I'll also note that the rims I bought came with new nuts which were the wrong size for the evo studs.
Overload in Colorado
Old Feb 23, 2005 | 02:19 PM
Nothing we carry. A wheel has be already be produced to accept a centering ring. Since Cobra wheels are hub centric for Fords specifically, they don't have the overbore or correct taper to accommodate a centering ring. You will have to rely solely on the lugs to center the wheel, which isn't the best thing to do.
Old Feb 23, 2005 | 02:21 PM
tswift's Avatar
Team Dynamics will fit. 17x8" no spacers less than $200 wheel. I have a set of silver in stock and Black are on the way. Other colors in a month. Pm me for more info.
Old Feb 23, 2005 | 04:58 PM
Slowride's Avatar
Rota Torques and probably others fit without spacers.
CodyJamesBitxh
Mar 8, 2016 06:02 PM
TurboTravis
Dec 15, 2011 09:00 PM
wspy
19
Jan 17, 2010 09:44 AM
LVSBB6
17
Jul 14, 2009 01:18 PM
Trbo Dad
70
Nov 2, 2005 08:11 PM
