Best brakes?
Originally Posted by BakZamGai
Hi trinydex
No word from ogvw as yet. Probably missed my question wading through all the posts.
My query as actually this:
Assuming the Mono6 calipers and say the Alcon XT6 calipers use the same pads, what advantages does the race-grade XT6 calipers offer over the Mono6? I know it uses Titanium piston inserts and this probably keeps the heat from the brake fluid but braking power wise?
Cheers
Dennis
Cheers
Dennis
humm yes your right on the discs, did not think of that. what about tha calipers? obviously a disc would have to be sourced to suit.
I see on the net many brembo 4 pot rear converstions, are these the same calipers as the fronts or smaller??
Emre
Maybe he wants to turn "trail braking" into "tail braking".
MOVIT brakes are superb...I have a front set on my car and have yet to cause them any problems on the track, fade free braking lap after lap after lap....
4 pot monoblock calipers running 343mm 2 piece disks...These fit under 17inch wheels and perform superbly....
quote=Phil_FQ;4018818 MOVIT brakes are superb...I have a front set on my car and have yet to cause them any problems on the track, fade free braking lap after lap after lap....
we are strong advocates for stoptech, almost all cars in speed world challenge use them etc... and ive had excellent experience with them, their support is second to none.
we have one of their first 355mm 6 piston setups coming for our evo 2.3 shortly.
cb
cb
Great stuff too... Probably the best on this side of the pond...
To be honest, 95% of Evo owners have no business going passed Ferodo DS2500 pads/good lines/and only a decent fluid though.
ogvw has a setup that fills in the mid range between my list and professional cars...
Ok Guys as I have just read nearly the thread to find out weather the wilwoods are any good or not and I have not been able to.
My Question is the 6 pot conversion kit with the 355 mm rotors on the wilwood range an upgrade on the standard Evo 9 ?
If so how much improvement?
and were does the Alcon setup fall in here. ?
What sort of dollars would you consider worth spending to upgrade to the full 6 pot kit?
does wilwood make an evo kit? because i think you should be more concerned with the diameter of the pistons... than the diameter of the rotor.
alcon/ap makes a kit. it's good. it's most expensive.
Dave
Anyone have experience with the Racing Brake one piece rotors? Needing a track/autocross/street setup. Already the stock setup is pulsating when I brake. Can't believe all the great reviews of the stock setup in mags as I am pretty unimpressed with the stock setup.
