Does this seem okay?
ive read through some threads about alignments. And i mentioned it to the tech who aligned my car. (btw i just put on my hotchkis springs n swaybar after many hours in my garage) the tech ruled against all my suggestions per tire wear. He aligned my car as follows:
LF -1 RF -1.2
LR -1.3 RR -1.3
Toe 0 all the way round....
is this okay?
LF -1 RF -1.2
LR -1.3 RR -1.3
is this okay?
For a daily the -1.3 in the rear is probably a little too much and as far as the front goes, well, it will take someone who knows what they're doing to set it at -1. Which from what I understand means you have to take advantage of the wiggle room in the top mounting hole of the strut to get it even. As far as getting -1.5, rotate the top eccentric bolt to point 180 degrees opposite, it might yield you a little more than 1.5 though.
High_PSI
Mar 12, 2017 08:19 PM
shinobee1
May 28, 2008 08:48 PM
TexasRS
23
May 25, 2005 12:52 PM
rebel89_00
May 31, 2004 09:24 PM
