Removing Brake Rotors
Old Feb 21, 2005 | 04:28 PM
EvoBlade2000's Avatar
Question Removing Brake Rotors
Hello, I tried to remove my brake rotors but I couldnt get them off. It looks like you just take off the wheel and the calipers and the rotor comes off, but I couldnt get it... there is lots of rust in there so I suspect that is the problem... I tugged and tugged but i thought I was going to pull my car off the jack stands. What size bolts do you screw into the rotors to force them off? Thanks for the help guys...
Old Feb 21, 2005 | 04:30 PM
JTB's Avatar
JTB
I am assuming you are referring to the front rotors?
I pulled mine off last saturday. All that was necessary was to pull the wheel and the remove the 2 bolts for the caliper. The rotor just slides right off from there.
It should be easy.
Old Feb 21, 2005 | 04:33 PM
tokeone's Avatar
there should be a bolt hole on the rotor that you can screw a bolt into and pop it off if youre having a problem
Old Feb 21, 2005 | 04:47 PM
chrisw's Avatar
yup, use a 10mm bolt (same size and thread of the bolts used to bolt the heat shield to the exhaust manifold.
the bolt screws right in, rotor comes off..
smileduck
Nov 21, 2017 06:22 PM
dethrock
Jan 7, 2017 10:43 PM
OldRiver05ES
Feb 18, 2009 10:18 PM
webguy330i
Aug 23, 2005 07:55 AM
vtluu
Aug 10, 2004 12:13 PM
