Coilover meltdown - too soon?
I thought I'd share my latest experience with my JIC coilovers with my fellow EvoM members. I was driving home last Monday night when I started to hear some clunking from my car's left front - almost like perhaps the bolts on the strut tower bar had worked loose.
When I got the car home and jacked up, fluid started draining out from the base of the of my driver's side coilover onto the inside of the rim. A through check of everything revealed that the source was indeed the coilover, and now the piston seems to rattle freely inside body of the coilover. I'm not sure if it's going to be rebuildable or not yet; I will try need to get more info.
My struts have seen about 20K+ miles of street use with quite a few miles on very uneven, wavy concrete. They have also seen a dozen or so track days (HPDEs on larger tracks), along with all the wear associated with that kind of use. For reference, these coilovers were NOT purchased from an EvoM vendor.
Is this typical of the life span for a set of these cilovers? I was hoping to get a bit more time between rebuilds. If this is typical, what manufacturers offer products that can stand up to a bit more abuse?
I think this is the typical lifespan for coilovers. I have Zeals and Endless estimates rebuilds every 12,000 to 15,000 mi. I think Ohlins are around 18,000mi. The really high end racing coilovers have even shorter lifetimes, I believe.
I think one of the big factors in the failure was one of the freeways I drive almost every day. Think of it as 15 miles of wide, small waves, like you'd find on a fairly still lake. If I go almost anywhere, that's the first bit of road I cover.
The spring rates and valving were the early, very hard 10K front / 9K rear set-up, and that bit of pavement really worked the suspension. I'm wondering if a softer set-up might have better survivability given my need to cover that road every time I take the car out?
Any info from the vendors?
Hopefully you've gotten your coilover fixed by now.
240sxzenki
27
Nov 5, 2010 03:42 PM
evo_soul
Toronto Lancer Club
Sep 11, 2010 05:51 AM
Bster13
45
Jan 12, 2009 06:41 AM
GTWORX.com
51
Oct 29, 2008 08:29 PM
SuperchargedGTZ
Mar 16, 2008 11:32 AM
