will this clear brembo??
Old Mar 29, 2005 | 12:54 PM
invazn's Avatar
i know stock is 17x8+38.will this one clear the brembo??can it be mount on stock advan?
5H/100
Old Mar 29, 2005 | 01:00 PM
Czubaka's Avatar
That's a subaru wheel, it won't work on the Evo. The bolt circle diameter is all wrong. Theirs is 5 x 100 and we're 5 x 114.
Old Mar 29, 2005 | 01:08 PM
invazn's Avatar
17x7.5+35 with the correct diameter ok?
Old Mar 29, 2005 | 05:14 PM
Czubaka's Avatar
Well, the answer is still an adult diaper...it depends. It all depends on spoke clearance from the caliper. The offset is just for the hub mounting surface and doesn't offer any real insight into how much caliper clearance you're afforded.
What kind of rims are they? Also, why would you want to go with a narrower rim than stock? Unless you're planning on using them for snow or gravel tires...
Old Mar 30, 2005 | 02:02 AM
Yogi_B's Avatar
Evo5,6 wheels are 17x7.5 +38, so 17x7.5+35 should fit, but then again spoke design plays an important part.
I tried my brothers 18x8 +35 wheels on my car, nope won't fit, the inner spoke towards the hub catches the calipers.
Old Mar 30, 2005 | 02:13 AM
500whp.com's Avatar
the offset will but not the 5-100, evos are 5-114.3
Old Mar 31, 2005 | 12:17 AM
RaceBiscuit's Avatar
MurtazaDSM
Dec 23, 2015 07:40 AM
fabcas311
15
Mar 25, 2014 10:10 AM
tmaddox
15
Oct 14, 2013 12:22 AM
blueprint
Mar 11, 2009 12:36 AM
Voltex9
18
Sep 23, 2007 06:07 AM
