RA-1's Noisy?
Old Apr 12, 2005 | 09:37 AM
taylor's Avatar
RA-1's Noisy?
I have a set of ra-1's w/ 5000 miles on them and they are pretty worn. I'm just curious how much noise other people are hearing with these tires. Mine sound like a moderately loud high pitch hum at steady speed(60mph) changing to a lower pitch "ummm" sound below 20 mph. They have slightly more inner edge ware, if it matters. The noise does not bother me, I just want to make sure it's not my t-case going south.
BTW, the sound does not get louder with speed, it just changes tone. If anything it dimminishes above 80mph, and is there regardless of gear/rpm. This is what is leading me to believe it's the tires and not something mechanical.
Old Apr 12, 2005 | 09:41 AM
number 8's Avatar
I've got RA's in about the same condition, and I don't notice noise like that.
Old Apr 12, 2005 | 11:07 AM
evo81's Avatar
not loud at all.
Old Apr 12, 2005 | 02:48 PM
kekek's Avatar
Mine do make a light "hum" if you want to call it that (full tread). WAY way quieter than my worn Advans.
Old Apr 12, 2005 | 06:09 PM
taylor's Avatar
thanks for the replys. To give you some idea of the noise level, with the stock radio, I have to turn the volume up to 26 to drown out the noise.
also, i forgot to mention that braking at low speeds changes the depth of the "ummm" sound as well, and also causes a very slight vibration.
BTW, could a sound like this be an indication of a bad transfer case? (I'm at 17000 miles with no launches FWIW)
TigOLDBiTTies
Dec 3, 2012 06:03 AM
AEvans190
31
Sep 19, 2009 03:51 PM
Dammit Cubs
Sep 26, 2008 12:53 PM
grcygetr
12
Aug 9, 2005 02:58 PM
taylor
May 4, 2005 12:30 AM
