POWER BLEEDER - What do you use?
Old May 25, 2006 | 07:18 PM
  #91
marksae's Avatar
Thanks for the info guys. I just ordered mine.
This is gonna save me so much trouble since I bleed my brakes before every track day!
Old Jun 1, 2006 | 09:52 AM
  #92
justchil's Avatar
Finally got to drive my car... my brakes are spongy tho.. I'm going to manually bleed them although I'm not sure what I've done wrong.
Old Jun 1, 2006 | 12:10 PM
  #93
trinydex's Avatar
^ hmm... let us know what is going on with this.
did you bleed with car on? off? did you pump the pedal at all?
Old Jun 1, 2006 | 03:25 PM
  #94
WarmPepsi's Avatar
after you get done, leave the cap off, get in car, push to floor twice, then check fluid level, and top off if needed. (may have put a touch of air in the master cylinder. )
Old Jun 1, 2006 | 04:24 PM
  #95
justchil's Avatar
I'll give that a try man!
The car didnt run when I bled the brakes... the pedal felt stiff but it was locked lol.
It really doesnt feel too bad... There isn't much stopping power yet because the brakes don't even have a mile on them
Old Jun 1, 2006 | 04:29 PM
  #96
WarmPepsi's Avatar
only thing i've found, is that sometimes i'll be bleeding and come up and see the pressure on the bleeder is still up there, but the line going to the reservoir isn't full of fluid, so i pick up the bleeder and drain some down to it.
Old Jun 1, 2006 | 04:35 PM
  #97
trinydex's Avatar
is there any merit in bleeding with the car on? back when i was mucking and chasing my plugged caliper problem i did it a few times... felt it might give the system a more full flush
Old Jun 1, 2006 | 07:46 PM
  #98
justchil's Avatar
Well the brake pedal like "locks" when the car is off.. I'm not sure if you can just put the key in or not.
I did what you said warmpepsi and it helped out a good bit. I still think I'm going to rebleed them tho. I had to put more fluid in.. went out for a 10-15 mile ride and it needed even more fluid. I'll triple check tomorrow for leaks.
Old Jun 2, 2006 | 03:34 AM
  #99
WarmPepsi's Avatar
well, if the reservoir was down and empty when you refilled it, you just put air back in your lines.
If it's down, but not empty, you're normally ok.
Old Jun 2, 2006 | 04:12 AM
  #100
justchil's Avatar
It was still above the minimum line... I think it will be OK the couple days it takes to get more Motul Thanks for the help man!
Old Jun 3, 2006 | 07:01 AM
  #101
EvilBlueEvo8's Avatar
used mine for the first time yesterday. works great. just one point that i might add. you should continue to open and close the bleeder valve on the one you are bleeding. i'm not sure why this works better but it does. i got half way done with the car and as i was closing a valve i noticed a bubble and i opened it again and there were a ton more. i started over with this opening/closing procedure and it seems pretty effective.
Old Jun 3, 2006 | 07:14 AM
  #102
justchil's Avatar
Yup I noticed the same thing ^^
How does your pedal feel now though?
Old Jun 3, 2006 | 01:25 PM
  #103
Haven't really tested it out yet. I also did ss lines, slotted rotors, and pads so i had to break them in and let it sit for an hour. Went to take it out today but it was raining extremely hard. Hopefully when the rain lets up tomorrow, I'll be able to really try the new combo out.
Old Jun 4, 2006 | 12:55 PM
  #104
justchil's Avatar
Well I found my problem.. it was my fault. For some reason or another I put 2 washers on one side of the banjo bolt when installing SS lines on the FR. I fixed this and rebled this wheel manually and everything is PERFECT.
Old Jun 4, 2006 | 02:37 PM
  #105
still breaking my combo in. defintely feels better though. its starting to bite harder now that its gots some miles on it. pedal feel is firm, but not heavy.
