Lug Nuts Changing Question
Old Jul 14, 2005 | 08:24 PM
Don Clarence's Avatar
If I am ONLY changing the lug nuts, do I have to jack up the car/wheel/tire to get it done? Or, simply just change the nut one at the time while the car is sitting on the ground.
This question may seem stupid but I do need some input. Thx.
Old Jul 15, 2005 | 06:50 AM
00R101's Avatar
I would be inclined to jack it up. When on the ground, loosening a lug nut at a time may put more stress on the wheel/hub assembly or may lead to uneven tightening. It would probably be ok but it seems like you risk a lot just to save a little extra work.
Old Jul 15, 2005 | 07:23 AM
PVD04's Avatar
There should be no problem changing them one at a time. When you pull the wheel off, you have to loosen the lugs on the ground anyways. Just pull one off, put the new one on and torque it down. I can't guarantee that you won't have a problem, but that's how I would do it.
-Paul
Old Jul 16, 2005 | 06:19 PM
MaxR's Avatar
if you're using new stock lug nuts don't worry about jacking it up. if you're using new aftermarket lugs, jack it up and do all 5 at one time. i'm saying your wheel might not like mixed lugs.
Old Jul 18, 2005 | 06:49 PM
Thx for all the input. I went the lazy way and just changed them one at a time.
si00dcracer
Evo X How Tos / Installations
Jun 6, 2015 09:32 AM
cleudson
Oct 4, 2013 07:47 AM
danny93905
Nov 17, 2011 08:51 AM
Xtremist
14
Aug 6, 2010 01:55 PM
KZEVO
Jun 30, 2006 01:45 PM
