Rear Brakes
Old Aug 15, 2005 | 09:14 AM
2GDSM's Avatar
Rear Brakes
Guys-
Just replaced my rear rotors and pads yesterday. Finally got to take it out to break them in today and it seems like the drivers side rear rotor is dragging or something. It sounds like its dragging, but sounds much more pronounced when i make a right turn, loading up that side of the car/suspension. I cant seem to figure out what is making the pads drag or of its something else. Anyone have an idea? Thanks.
Old Aug 15, 2005 | 09:22 AM
Curt@MrLed's Avatar
Former Vendor
did you jack the rear up and see if the wheel is dragging.. is the caliper tight, was the rotor hard going on.. need more info, i cant see the car..
Old Aug 15, 2005 | 09:37 AM
2GDSM's Avatar
Popped the old rear rotor without too much fuss besides some rust, installed the new rotor and snugged it down with the lugnuts. All of the bolts for the caliper and everything are on pretty tight. The wheel dragging? What would it drag against?
Old Aug 15, 2005 | 09:42 AM
Curt@MrLed's Avatar
Former Vendor
draggin i mean are the breaks hangin up.. is the rotor blueing yet, excessive dust.. the most likely probs are, the pads are not fitting in the caliper right, thus getting stuck, there is a prob with the e-brake, or your caliper is frozen not letting the brakes release, poss. probs with the bearing.. jack it up and start looking around..
Old Aug 15, 2005 | 09:47 AM
2GDSM's Avatar
Alright thanks man, im gonna jack it up later, take the brakes back off and reinstall it. The brakes didnt blue or anything I dont think yet.
Old Aug 15, 2005 | 01:19 PM
2GDSM's Avatar
jacked it up, took everything apart and reinstalled it...It still sounds like its rubbing on the passenger rear when I make a turn... Anyone have any ideas? The pads are seated correctly, and it doesnt seem to really rub when going straight, just when making right turns and loading the left suspension, it doesnt even take much load in a turn to make it rub.
Old Aug 15, 2005 | 03:33 PM
2GDSM's Avatar
bumpity...anyone have any idea??? The damn car only makes the sound when im making a right turn, it doesnt even have to be a sharp turn. But as soon as I do, I hear dragging or something sound. The rear brakes work fine when I stop and make no noise when I push on the brake, only when im making a right turn, the left rear brake makes a sound...Cmon, someone's gotta have an idea cuz im seriously beyond stumped.
Old Aug 16, 2005 | 12:31 PM
Curt@MrLed's Avatar
Former Vendor
is your backing plate hiting.. if all else fails take it too a garage, or wait until you can see what is rubbing.. most really cant help you we cant see your car...
Old Aug 16, 2005 | 12:43 PM
nubby's Avatar
Registered User
40 +- 4 ft/lbs on the bolts that hold on the rear caliper. 73 +- 7 ft/lbs on the lug nuts. Those are some pretty important fasteners, and should be torqued to factory specs, just to be safe.
Old Aug 16, 2005 | 04:37 PM
2GDSM's Avatar
Nubby, I've got all of the bolts/nuts on very tight...I really still cant figure this one out...Brakes are going to be taken apart again tommorow to hopefully figure out what the problem is.
Old Aug 17, 2005 | 02:39 PM
Curt@MrLed's Avatar
Former Vendor
Nubby... what is that.. the backing plate being bent has nothing to do with bolts being tight...
Old Aug 17, 2005 | 02:49 PM
nubby's Avatar
Registered User
I quoted something to the effect "All bolts are on pretty tight", and when it comes to the braking system "pretty tight" is wrong, torqued to factory specs is right.
A bit of a tangent, but safe is better than sorry.
Smike
628
Oct 27, 2024 04:39 AM
Smike
63
Apr 29, 2019 07:27 AM
MrAWD
Sep 19, 2016 08:39 AM
toyotabike
10
Jan 30, 2013 10:17 PM
