suspention squeaking. please help
Old Nov 22, 2005 | 04:49 AM
deadbeatrec's Avatar
ok so far i have only noticed the rear suspention is squeaking , and only when its 40 degrees or below that. i think its the bushings but im not sure. its odd that it only does it when its cold out. anyone have any sugestions on what to do? ever happen to anyone else? i want to take it in but im afraid if i do and they drive the car, they wont notice the squeaking and i will be S O L. most of the time u cant hear it, but on a cold dry night it is as loud as a 13 y/o virgin. what do i do????
Old Nov 22, 2005 | 04:54 AM
also never done any auto x's and still on stock set up for now. the car is an 03 with 14,000 miles on it.
Old Nov 22, 2005 | 10:04 AM
bullfrg's Avatar
There is a rubber insert that the spring rests in on the upper rear suspension mounting point. This is where the noise is coming from. Not sure if there are any solutions my car has been doing it when it got cold since new. I am installing some WORKS pillowball mounts though and that should take care of it.
Old Nov 22, 2005 | 10:40 AM
well i do have a new set of coilover going in spring time , will that eliminate the noise or does that rubber mount get reused with the new suspension?
Old Nov 22, 2005 | 01:40 PM
bullfrg's Avatar
Should take care of it, the rubber piece is part of the upper mount and I do not think you would reuse it for any reason.
Old Nov 23, 2005 | 04:25 AM
cool thanks bro.
Old Nov 23, 2005 | 07:24 AM
bullfrg's Avatar
No problem.
black ralliart
Jan 17, 2017 11:30 AM
ilovebowbies
May 17, 2016 08:50 PM
LooneyToon
May 11, 2009 05:25 AM
smeghead009
Feb 2, 2008 05:54 PM
shbomb8188
Sep 26, 2006 05:13 AM
