Size tires to run
Size tires to run
Heres what my plan is. Getting some 18x8's or 9's aint sure yet. Car has been lowered with Tein S-tech springs not sure on drop i guess about 2in or a half. Im running 235/45's right now and they are very close to the fenders. With these 18's am i going to have to run a 225/45? or even smaller like a 215/45?
Any help would be great thanks!
To make this easier this is what im goin to run
http://www.discounttiredirect.com/di...112&vid=008389
I'm running 255/40/18's on an 18x8.5 wheel with +35 offset. Get a little rubbing due to negative camber up front. Probably would have been ok, had I ordered the right size tire! (255/35/18).
this is a good tire size calculator too... www.1010tires.com/TireSizeCalculator.asp
as you go wider the shock of having a smaller profile is less because the width of the tire takes up a lot of the road shocks, like it's a bigger trampoline surface if you know what i mean.
crap i misunderstood that post... the thing is if you have a larger profile on a thinner tire you can run stretched, which allows you more "slam" room.
dizzle06ix
11
Jan 10, 2014 11:47 AM
Alberto521
Feb 20, 2013 09:43 PM
WRX1832
May 18, 2003 11:30 PM
