View Poll Results: Which Suspension Setup?...DMS 50 - Ohlins RT - ??????
Voters: 113. You may not vote on this poll
Ohlins or DMS 50
Originally Posted by Miotch
Personally I feel DMS is perhaps one of the best suspension systems on the market. However, I have little experience with ohlins, so I can't really comment.
BUT......
I would like to challange anyone with Ohlins. I'll even pay for your entry fee. Where and When?
Colorado Off Road Extreme. When ever anyone calls me and wants to do this thing and settle it once and for all. 303-296-3030
I'll bring my subaru 2.5 rs with 50mm NGs on em. Or if you are in the area and want a ride to see what they're like, feel free to call me on this as well. The course is gravel and really smooth. However, if you wish, there is oportunity for some serious air. We'll see which system stands up better in a rally envioronment. You don't need a cage or Skid plates but I recomend you bring them.
Here is a video of the course. www.cp-racing.com/files/CORECLANND.wmv
The RS is running 40mm DMS in this video.
Seriously, Call me if you want to do this thing.
Mitch
www.checkpoint-racing.com
303-296-3030
2851 Larimer St
Denver, CO 80205
BUT......
Mitch
303-296-3030
2851 Larimer St
Denver, CO 80205
We are talking about street suspension, or in rally terms "tarmac". What would a test of your gravel rally suspension prove? And for the record I have seen DMS rally struts break in two, and DMS has about the worst customer service ever. I hear things are better now, but a few years ago dealing with DMS was a joke.
How bout this, you bring your little 2.5 RS with it's gravel suspension out to MMP in Utah and see how it does. Infact leave the gravel tires on and I'll run RA1's... that should prove all sorts of stuff.
Anyway, this is not about rally cars.
Here's a real question.
I have just purchased a set of secondhand DMS gravel suspension, and would like to know what the spring rates are.
know they are progressive, but the low rates are onlu for the first couple of inches of travel, then they look like they should be approx linear.
Front springs are: DSP-M-350-DP-350FL
Rears are : DSP-M-200-DP-350FL.
The second number (350) would appear to be the free length, so i'd assume the first number would relate to the spring rate, does it mean that the main rate is 350Lb/inch in front and 200 at the rear?
That just sounds a bit mismatched to me, I thought they should be closer than that.
BUT......
Mitch
303-296-3030
2851 Larimer St
Denver, CO 80205
BUT......
Mitch
303-296-3030
2851 Larimer St
Denver, CO 80205
Originally Posted by chronohunter
I would love too! My car is too low for jumps but it's plenty fun in the gravel (I live on a gravel road and have a looong driveway with a hairpin in it
). I couldn't download the Video so I'm not sure how rutted it is (that would be my only worry). PM me and let me know where and when
(even if it doesn't prove anything)
The guy won't commit to the corners ahead of time and throw the car sideways. So he ends up pushing the corner or driving around it "standard". It reminds me of my first day in a car on gravel trying to learn how to get 'er done.
They need to go watch some Pat Richard videos!
Originally Posted by chmodlf
Chrono
Do you have a street/autox setup vs. street/road race setup for the Ohlin RTs? Or would your normal setup suffice?
I am trying to attain that ever elusive (impossible?) compromise between a full autox setup (r compounds) that has 900lb spring rates and will be extremely stiff for daily driving (the roads in CT suck). I am willing to compromise some performance and some comfort as I do not have a dedicated race car.
Thanks
Thanks
Less trash talk. More info.
Please answer the legit questions...
Patience, I was busy today crashing my race car (at some point this season has to get better).
I can't wait to get my hands on a set of Vishnu/Chronohunter spec Ohlins. What else would an EVO owner want? You have an engineer, who happens to be a professional race car driver, that modifies and tests different combinations of Ohlins coil overs specifically to improve the performance of the EVO.
Keep up the good work
Wow, so angry yet so amazingly unable to answer any technical questions
Coincidence?...I think not
Robi (and Al) philosophy...when you don't know an answer (or get caught stretching the truth)...ATTACK!!!
We can setup up our off the shelf shocks anyway we want. Basic maybe, but why risk the chance of in-experienced suspension gurus messing up a curve that works. Granted, and I agree, it leaves something to be desired for SOME people, and is not ideal for 100% conditions. It suits over 95% of people and conditions we have come across so far. Reason is simplicity as well.
Custom setups make it virtually impossible to offer technical support unless you know exactly what the customer has done to their shocks? Being a small company DMS simply does not have the man-power for this, so we only offer customizable valving on the three, four, five, six and seven way units. We are no longer talking about a street setup, and unless you have access to a dyno and some heavy knowledge, you can not re-valve these to meet your needs.
Kind of like this, entry level systems for entry level customers (no offense intended to anyone at all). The more we design into a shock as far as what the customers can do with them, the more experience that is required to set them up.
You would be surprised how many customers call with difficulties tuning a seperate rebound adjustment (like on the 50mm). No imagine if they are modifying low and high speed settings?
Anyways, my two cents for today
And I still think OHLINS is a good suspension manufacturer, but ask them to give you a recommended setting on a custom valved setup by joe blow from the corner shop? It is difficult for them to give a recommendation with no info at hand.-mark
PS: Good idea mitch, we will need to do a gravel test and tarmac test though
I have lent a set of 40mm to ROBI to do some tarmac testing. I hope he will install it in a car that some people can drive besides the owner. Get a wider range of feedback.
Cool video Mitch, and I suggest any off-road, or rallycross guys take mitch up on his offer!!!!
Originally Posted by DMS_Mark
Will help out a little here..
We can setup up our off the shelf shocks anyway we want. Basic maybe, but why risk the chance of in-experienced suspension gurus messing up a curve that works. Granted, and I agree, it leaves something to be desired for SOME people, and is not ideal for 100% conditions. It suits over 95% of people and conditions we have come across so far. Reason is simplicity as well. Custom setups make it virtually impossible to offer technical support unless you know exactly what the customer has done to their shocks? Being a small company DMS simply does not have the man-power for this, so we only offer customizable valving on the three, four, five, six and seven way units. We are no longer talking about a street setup, and unless you have access to a dyno and some heavy knowledge, you can not re-valve these to meet your needs.
You see where I'm going with this? We have a system in place that removes these issues. I am hired by Vishnu to develop systems of suspensions. I involve a major universities motorsports engineering graduate program. Or resulting testing and research includes everything that could be considered a variable and eliminating it. We then give the customers every setting down to tire and tire pressures rim widths and offsets all alignment settings etc.etc. We can give anyone at any level a first rate reasonably priced suspension system that will work as advertised. I communicate with each customer individually to make sure it has the balance they desire between street and track performance. This is why I boldly state that our set-ups will outperform more expensive options.
Originally Posted by jid2
Paul,
I have decided that you should just sell me the Ohlins OFF your car. Since there are none for me to buy, and you keep telling me why I SHOULD buy them!
You guys do realize that you could get JRZ's, Ohlins 2 ways, Motons etc. and we can re-valve them NOW. Yes you'd have to spend more but you would get a fancier shock (won't perform any better but they're cooler
What type of driver buys the 40mm? someone with...Daily driver sometimes track?
What type of driver buys the 50mm? Full blown race car?
Are you saying that the DMS 40mm are the same playing field as the Ohlins R/T
and the DMS 50MM are on a higher level?
I also see the price range for the DMS 40mm and Ohlins R/T are about the same
Im just asking...just want to know...that why I started this thread
thanks
So does the formula below look correct to you?
DMS 50mm > Ohlins R/T = DMS 40mm
Im just asking...I dont know
