Rear suspension creaking noises over bumps - causes?
Guys, in need of assistance. Lately my MR has been experiencing some loud squeaky noises when going over large slow bumps specifically when the vehicle compresses down from the bump.
It has not always done this, only recently I might add.
Im running the Swift MR springs and Perrin rear sways, wondering what could be the causes?
Thanks in advance!
Thanks in advance!
Originally Posted by DaWorstPlaya
Aftermarket springs causes all sorts of squeeky noises. You should have greased up the spring contact points before the install to avoid the noises.
also, check to see if your bushings on the sway have some lithium grease on them. They can get clunky when they start to dry out.
suspension...springy type of noise only when the car really digs deep after a large bump, regular around town type of stuff there is no such noise.
Im cleaning the springs now and also moving around the rubber things that coil around the spring...that might be the culprit?
Bingo, rear sway bar bushings it is.....THANK YOU for the suggestion. A quick trip to pick up some mobil 1 grease and 15 minutes later shes good to go, problem solved.
EvoIXPilot
36
Aug 8, 2018 08:03 PM
jos76
Outlander Sport
38
Jun 18, 2017 06:04 AM
Mr.Sparkle
757
Apr 18, 2017 08:04 PM
Sanny632
Sep 20, 2011 01:30 PM
