Hotchkis and Bodyroll
Old Apr 3, 2006 | 10:32 PM
Enyth's Avatar
Question Hotchkis and Bodyroll
I recently installed my Hotchkis lowering springs and I noticed that, although the ride is smoother, I have more bodyroll in the car when I take turns. I didn't really plan on having more bodyroll obviously And this bodyroll is starting to really annoy the crap out of me. So my question is, how do I get rid of that bodyroll? I tried searching but I end up with nothing at all. I remember searching a while ago, but now I can't seem to find it.
From what I can remember, people were installing rear sway bars along with the lowering springs. But there was never a clear answer on if it got rid of that bodyroll. People were saying it improves the handling, but does it also get rid of that bodyroll? If anyone can provide feedback, that would be great. Thank you.
-Enyth
Old Apr 3, 2006 | 10:39 PM
bluebanana23's Avatar
I've heard a lot of lowering springs actually hurt performance like the tein-s and such. Try installing a rear sway bar and you will be happy once again.
Old Apr 3, 2006 | 10:53 PM
Speed Element's Avatar
like the one stated above.. get a rear swaybar and you will notice much less bodyroll.
Cusco, Perrin, Whiteline, SWIFT and many others make great Rear Swaybar for EVO.
Old Apr 3, 2006 | 11:26 PM
Enyth's Avatar
ok thanks for the info guys im definately looking into the swift rear sways, anyone have any preferences?
Old Apr 3, 2006 | 11:33 PM
4WS Tuning's Avatar
sway bars!!!!!
Old Apr 4, 2006 | 07:46 AM
russjnco's Avatar
Agreed, a rear sway bar will definitely help but you will still have some roll.
Old Apr 4, 2006 | 07:54 AM
9g's Avatar
9g
yup. swaybars would help.
Old Apr 4, 2006 | 08:13 AM
jid2's Avatar
You need to understand what all the parts of your suspension do. Just because you lowered your car you can't expect the body roll to be gone. The spring rates of the Hotchkis springs are roughly stock, so you should expect stock like body roll, with a small improvement gained by the inch of lowering.
Even with a swaybar you are going to have body roll, how much... a fair amount. I say this because I have Hotchkis springs on my car and a 25mm Progress rear swaybar. Out on the track my car still has lots of body, not as much as stock, but still a fair amount. But for $300 worth of suspension upgrades it offers great improvement over stock.
If you want to remove more body roll you need higher spring rates, both Eibach and Espiler (sp?) make springs with higher rates. I hear they ride pretty harsh on the street. Your other option is to step up to some coilovers.
Anyway, don't expect just a bar to solve the problem, it will help for sure, but the roll will still be present.
Old Apr 4, 2006 | 08:40 AM
DaWorstPlaya's Avatar
Well said jid2, the only way to control body roll is by using either:
1. Stiffer springs
2. Stiffer dampeners
3. Thicker sway bars ...
In each of these cases you will have to apply them to the front and rear. Mind you there will be side effects on the handling characteristics both wanted and unwanted for doing these mods.
Old Apr 4, 2006 | 08:45 AM
SoR's Avatar
SoR
I don't get it. You install lowering springs without changing the dampers. Your handling gets worse. Then you change the rear sway bar so you reduce the rear grip. All bad choices.
If you want better handling and plan on changing the rear sway bar, you should at least get coilovers. Otherwise you're making the bad thing worse. Next thing you know is, you'll have oversteer. Sideways is not the fastest way around
Old Apr 4, 2006 | 08:55 AM
Soon2BEVO's Avatar
Thank you for pointing this out!
If you're expecting some sort of big performance gain from $150 dollar springs, your sadly mistaken. They are intended for looks, not performance. Get some coilovers and youll be happy.
Old Apr 4, 2006 | 08:58 AM
redteam22003's Avatar
Would a rear sturt bar help?
Old Apr 4, 2006 | 09:01 AM
Soon2BEVO's Avatar
Barely. A rear strut bar i also going to make the rear slide out easier, thats the last thing I want in my street car. If I ran at the track thatd be great.
Old Apr 4, 2006 | 09:23 AM
EVO8LTW's Avatar
It's not a surprise that your car rolls more being lowered with those springs. If you do some studying on strut suspension design, you'll see that lowering the car can increase the amount of body roll (all things being equal) because of the change in the relationship of the roll center and the center of gravity. This is another reason, other than decreased suspension travel, that you want to increase spring rate when you lower the car. However, higher rates don't work very well with stock shocks (i.e., bouncy and underdamped), hence the fact that coilovers are generally the way to go for lowering. Of course, then you've got a harsh ride to deal with unless you spend a lot of $$ on top of line parts.
Old Apr 4, 2006 | 05:56 PM
jid2's Avatar
The Hotchkis springs are not low enough to make body roll worse than stock. What you say is true if you lower the CG to the point that it creates a larger moment about the roll center by extreme lowering. But that is more drop than the Hotchkis springs provide.
The spring rates are the reason the Hotchkis springs still have body roll.
