Infinity G35 18" rims
Old Apr 6, 2006 | 07:02 AM
Roamer's Avatar
Does anyone know if these will fit an Evo? They have the correct bolt pattern and a +30mm offset. Clearance should not be a problem as they come standard on G35 Sports with the Brembo brakes. However, I am concerned about the hubs.
Thanks!
Old Apr 6, 2006 | 07:13 AM
SuperHatch's Avatar
G35 has a 66.2mm hub bore, Evo has a 67.1mm... sorry.
Old Apr 6, 2006 | 07:39 AM
Roamer's Avatar
Thanks SuperHatch!
Could they be machined? Would .9mm effect the structural integrity of the rim?
Old Apr 6, 2006 | 07:45 AM
SuperHatch's Avatar
Sure
Impossible for me to know. Generally you don't want to machine cast metals. In this case you won't need to machine the entire hub bore, only the first 8-10mm or so. You're talking about taking 18 thousandths off of the radius of the hub. That's a very small amount, I'm sure you can get away with it. Just make sure you have a competent machinist do it for you.
Old Apr 6, 2006 | 08:20 AM
TheGVR4kid's Avatar
I remember the Tacoma guys were machining out the bore of IS300 wheels and using them, don't remember anyone having a problem.
Old Apr 6, 2006 | 12:24 PM
value's Avatar
Aren't they pretty heavy
Old Apr 8, 2006 | 02:15 PM
Roamer's Avatar
Thanks again superhatch and thanks for the info GVR. My father-in-law is a top-notch professional machinist, so that much I have covered.
Value, I saw them listed as weighing about 20lbs, so they are consistent with other cast wheels of this size.
Old Apr 9, 2006 | 07:23 PM
SuperHatch's Avatar
make sure you take pictures when you've got them on, I'd love to see how it looks...
Old Apr 9, 2006 | 07:34 PM
ThunderOZ's Avatar
dont they have the infinity symbol on the rim?...correct me if im wrong but that'd look kinda weird...
Ha_ze
55
May 26, 2006 10:48 AM
Derek888
Mar 2, 2006 05:05 PM
neal540
19
Oct 22, 2004 11:12 AM
bobaab
43
Feb 26, 2004 04:22 PM
