If my calculations are correct - Stock vs. AP vs. Brembo
#31
Originally Posted by fromWRXtoEVO
x838nwy,
The comparison is great, unfortunately is just gives you size parameters when in the real world you actually have to consider additional factors such:
Surface area or rotors
weight of rotors
surface area of brake pads
material of brake pads
material of rotors
disipation heat porcentage of each material based on metal estructure
ventilation of each rotor
Even the rims play a important role disipating the heat, put some steel rims like the GSR Evo in Japan and your temps will remain higher, brake with well ventilated rims and your heat will disappear faster
Sumarizing, you can have a bigger rotor and be less efective than a smaller rotor, there are more variables to consider but good info that you provided .
Carlos
weight of rotors
material of rotors
Carlos
The info here by no means conclude that one make is better. Just to give an indication of the kits available. Other parameters also matter, but they're just not possible from my vantage point to work them out.
Thanks for pointing it out though!
C
EGbeater
May 1, 2019 11:15 AM
Treyzian
35
Mar 31, 2016 10:36 PM
andreitentean
Feb 5, 2011 01:56 PM
nubby
52
May 19, 2006 11:03 AM
