Endless big brake kit...whos got them installed?
Originally Posted by termsheet
I put high temp fluid and stainless lines on the stockers and still warped the rotors after a few track days. This is pretty common. I just ordered some Stop Techs. They seem to be the best big brake kit value that I've found. Unfortunately the company just sold and they are low on inventory. I'm being told 3 weeks at the earliest. It would be interesting to have someone (maybe a vender) list all the major Evo kits with market prices. I looked at the Brembos and APs but they were a lot more than the Stop Techs.
Everyone thinks a pulse in their brakes is a warped rotor. Go out and bed your pads in again, and then let them cool. Tell me if the problem is solved. (almost certain it will be).
Originally Posted by WarmPepsi
and you're 100% positive you warped them, and it's just not uneven pad deposits.
I've actually seen several sets of warped rotors come through our shop. Someone posted a thread awhile back about trying to get their warped rotors warrantied. Mitsu replied that they warped rotors are not a defect, but rather the result of off-road driving.
I checked the pads when I pulled the brakes off and they looked fine. The rotors on the other hand... didn't fair so well.
When i get set to track again, wow, don't ya know, still pulses. Take it out for 2-3 hard brakes, 80-30. Let it cool without hitting the brakes, and bam, ready to go, all extra pad compound removed, and ready for another track day.
- Rotora is made from parts sourced from vendors in Asia. It's also assembled in Asia. No one knows where the parts come from.
- Stoptech is made from parts sourced from vendors in Asia. It's ASSEMBLED in the USA. Their calipers are probably made by VTTR or some other vendor out of Taiwan (www.vttr.com.tw/)
Neither source parts from Japan. And there's a huge quality difference.
Might want to read the first two pieces in the following link.
http://og-made.com/archives/category...s-innovations/
Stoptech:
Rotors are made in Italy
Hats, brackets, and brake lines are machined in house by Stoptech in California.
source -> www.stoptech.com
- andrew
Originally Posted by stoptech.com
StopTech's ST-40 and ST-60 calipers are manufactured using a squeeze-forging process at Sanyco, a 34-year old company that is CNS, QS 9000, and ISO 9002 certified. Mitsubishi®, Volkswagen® and Toyota® are among their top customers.
Sanyco delivers raw caliper castings. StopTech does all finish machining (such as piston bores sized correctly for the application), assembly and test in California. StopTech tests every single finished caliper to 2800 psi using brake fluid on a special test bench designed by StopTech engineers.
- andrew
Nadaevo
Feb 17, 2017 01:48 PM
Lancestuh817
Lancer Aftermarket Forced Induction Tech
38
Jan 15, 2005 11:10 AM
