Anti lock light is on
Old May 10, 2006 | 04:33 PM
silverghost's Avatar
Question Anti lock light is on
I did an HPDE event at Gingerman last weekend. I drove all day at the track without any issues. I let a good friend do 3-4 laps in the car. He brought the car in because he was having some fuel pickup issues. When I was driving back home after fueling up I noticed the the anti lock light would come on after a mile or two on the freeway. Does anyone know what the problem could be. Has anyone repaired this problem?
I have changed wheel sensors in other cars. My understanding of the Evo's electronic force distribution system (EBD) is that it uses G meters and steering wheel sensors in conjunction with wheel speed sensors. I don't seem to get any brake diagnostic trouble codes. That is, the anti lock light does not flash when the ignition is turned on without starting.
When I start the car the anti lock light is off. However, the ABS occassionally pulses when braking lightly. After a variable period of time the anti lock light will light and remain lit until I shut the car off. The false ABS events subside once the light comes on. This suggests to me that a wheel sensor is bad. Does this sound right?
Old May 11, 2006 | 05:22 PM
trinydex's Avatar
you abs is broken... when the light comes on chances are the abs is disabled entirely.
Old May 13, 2006 | 05:59 AM
rsr14's Avatar
Maybe some tire debris from the track is stuck to the sensor ring and giving a false signal every now and then?
Old May 13, 2006 | 06:45 AM
MuslimEvoFreak's Avatar
If the ABS comes on during light braking, then you have probably chipped one of the teeth and it needs to be replaced. I had the same problem and had to go to the dealership to get it replaced.
IX_MR
Feb 21, 2020 08:46 PM
killerpenguin21
Jul 11, 2018 10:41 PM
Rotten Egg
Oct 26, 2011 05:16 PM
mirebih
35
Dec 4, 2010 05:44 PM
Midnightevo8
24
Feb 18, 2010 06:58 PM
