Brembo Breaks Squeaking (Merged)
man im having the same problem with my pads right now i just bought my evo
and the old owner changed the rotors but left old hawk hps on with no shims
i just orderd a new set of pads hopefully this will help but i think i'll need to
go to the dealer and pick up new shims
Loudest squeal brakes!? Help
i just installed EBC red stuff on my brembos, factory rear rotors and drilled front rotors. I dont even wanna drive my car anymore because of how loud the squeal is when your coming to a complete stop, its the most annoying thing ive ever heard in my life. HELP i can not drive it like this. i even took them out again and made sure everything was cleaned and reinstalled them, i double check everything please help i can not take this anymore.
i used the supplied shims that came with the EBC pads, i had grease inbetween the pad and piston and was doing the same exact thing so my mechanic requested i go home and take off the grease bc EBC doesnt recoomend any grease on the back of their pads so i redid my whole job and wow still HUGE noise, i did not rough up the rotor
I'd rough them up with some 120 grit.
New brake pads usually have a thin layer of material specifically for bedding. If the rotors aren't rough, this will affect braking performance and noise.
Also how did you break the pads in? Ferodo recommends 20 minutes of 50% pedal in corners.
I have these same pads on an not a single squeal since the day of install. After 2k miles still no squeal.
i greased the backs, the tops (where metal cross sits) and the shims and they were really really loud, was i supposed to grease the pins? and the cross metal really is pushing on the top of the pad is that suppossed?
