Rotor info needed!?!
I did a search
How do you remove the front and rear rotors? Do you just take the calipers off (not bleeding the calipers) and they slide off the Hubs? Any info would be greatly appreciated!!!
Originally Posted by 4G63
I did a search
Basically, take the pads off, then the calipers - find something to support the calipers once they come off - then the rotor should sort of slide off. A little persuation might be required, but they do slide off.
Becareful with the torque when you tighten the caliper bolts on the reinstall. Use about 80+/-7 lbft
If you prefer, you could take the brake line off also, but that's messy. The banjo bolt there should be 22+/-4ftlb.
I did a search
Jack the car up, remove the wheels. Undo the 2 bolts holding the caliper on, slide out, pull off, replace.
On the rears, make sure you release the parking brake, makes it a wee bit easier
Thanks 2 both of you!!!!! I thought thats how it was done. Ive done my rear pads, but now I need to do the front pads and all 4 rotors. Thanks a million!!!!
Drew314
31
Feb 16, 2020 04:34 PM
CatalystGod
Evo X How Tos / Installations
20
Dec 12, 2016 01:36 AM
Live4Redline
Aug 28, 2012 08:34 AM
MNTwins
13
Jul 14, 2011 11:11 PM
