A little alignment help plz.
Old Jul 6, 2006 | 07:33 PM
4g63t28's Avatar
Well I decided to align my 700mile old Evo today and as it turns out the factory alignment was way out. My question is about the ft. camber bolts. Can you rotate them like an eccentric, or do you need to leave them on the flats?
Before: L R After: L R
Rear camber--1'04/-1'13 -1'45/-1'45
Rear toe-0'05/0'14 0'01/0'01
Front camber--0'56/-0'44 -2'08/-1'54
Front toe--0'02/-0'01 0'01/0'01
Caster-3'49/3'48 3'49/3'48
I tried swapping the ft. camber bolts every which way, but that's as close as I could get them. There's still a ton of adjustment in the rear.
Old Jul 7, 2006 | 12:29 PM
4g63t28's Avatar
bump.
Old Jul 7, 2006 | 01:03 PM
DaWorstPlaya's Avatar
Yes you can rotate them like eccentric bolts to increase or decrease the -ve camber in the front. If I remember correctly, the arrows pointed in increases -ve camber ... it's been a while.
Old Jul 7, 2006 | 05:07 PM
4g63t28's Avatar
There's no arrows on the bolts. There's just two flat spots on the bolt which drastically change the camber. I'm guessing they're supposed to be left on the flats but I rotated one just for ***** n' giggles, and it seemed to work fine. I'm just wondering if anyone else has done that on a IX. I'm worried the bolts might loosen.
Deetz
Oct 23, 2009 11:19 PM
idriveanevo
11
Jun 16, 2009 09:45 AM
Evo8
Sep 19, 2008 01:49 PM
goofygrin
Sep 11, 2008 12:41 PM
ferrarokid
May 10, 2003 02:18 AM
