Alignment ! ! Read Me....
Old May 9, 2003 | 04:55 PM
ferrarokid's Avatar
Thumbs down Alignment ! ! Read Me....
Hey guy's get your alignments checked ! ! the way the car is SET IS NOT EVEN CLOSE !!
OUT OF THE BOX :
FRONT CAMBER -.30
FRONT TOE -.34 (total)
REAR CAMBER -.50
REAR TOE GET THIS... - .45 !! (total)
now :
front camber -1.60
front toe 0 (total)
rear camber -1.50
rear toe +.08 (total)
the car handles totally awesome ! ! !
guy's in the n.y - c.t area shoot me an email as i have an alignment machine on the premesis ! ! there is a trick to getting the maximum camber in the front WITHOUT grinding ! !
Old May 9, 2003 | 05:01 PM
iodine23's Avatar
This has been posted before, and I've even written up a bit about the eccentric bolt in the front in the how-to section. I've also posted the factory specs, do a search for "evo stock alignment" or something like that.
Old May 9, 2003 | 06:11 PM
TaiwanEvo's Avatar
so are the cars alingments off from stock or what.. i don't get it.. is the first set of numbers suppose to be stock.. or the second set of numbers are factory spec
Old May 9, 2003 | 07:06 PM
ferrarokid's Avatar
the first set of numbers are "as is" the second are where we set them !
Old May 9, 2003 | 10:41 PM
Jonasan50's Avatar
Strange?? The car doesn't pull, rides straight, sits flat on the road, tires wearing perfectly... Any signs to look for??
Old May 10, 2003 | 01:00 AM
Diesel's Avatar
so, because yours was whacked out, does that mean they all are...?
Old May 10, 2003 | 02:18 AM
I4K20C's Avatar
Where do you get your EVO allighned..
hispanicpanic
10
Mar 1, 2014 04:07 PM
Kento240
15
May 2, 2012 12:42 PM
19psi
13
Oct 8, 2006 09:08 PM
GOKOU
20
Apr 22, 2005 11:34 AM
