HELP! BREMBO brake pad help
i was changing my brake pads and my idiot friend pulled the inside pad out before i could compress the pistons. i have one side compressed but i dont know how to compress the other side with out scratching the rotor. if anyone could help it would be greatly appreciated.
First step is to relax (helps with all car work). Next, get an assistant to help bleed the system (a little). Loosen the bleeder valve, have your assistant pump the brake pedal to release a little fluid. The piston should now recess into the caliper and you should have plenty of room to slide in the new (thicker) pad. Although I won't get into detail regarding the two man bleeding operation, make sure you don't let any air into the system. Good luck.
Originally Posted by justchil
Did you take the cap off the reservoir? Ditto on the screwdriver.. just use a towel so you don't scratch anything.
Originally Posted by davids2004
Take it apart and do it again.
Carlos
Originally Posted by fromWRXtoEVO
First of all, don't let your stupid friend get in the car and press the brake pedal. Secondly go to home depot and buy a C clamp and compress the piston. The C clamp is cheap as hell
Carlos
Carlos
Yeah C-clamp or spreader will work too.
I just get a big flathead screwdriver put a towel around it and wedge it between the rotor and piston and pry. Or if the brake pad is still in you can use that to push the pistons.
LOL hopefully the piston didn't come all the way out or it will be a b!tch. Anyway, put half of the old pad between the piston that is already compressed and the rotor. Then, pry the piston up with a big flat-head screwdriver and who gives two effs about scratching the rotor
Anyway, so when they are both about the height of the pad, slide the pad back where it was, then pry the pad against the caliper with the flat-head screwdriver again. Always works for me. Also, don't do both pads at once, do one at a time.
the 2 pistons on the right are completley pressed in the 2 pistons on the other side of the caliper are extended out. how do i put them back in to slide new pads in?
