suspension clunk?!
Old Jul 25, 2006 | 05:26 PM
essjEVO's Avatar
suspension clunk?!
watsup... i got my tein h-tech springs on and its been installed a year ago. A couple weeks ago was when i started noticing suspension clunking or making springy noise. I only notice the noise when i slowly accelerate from first gear or turning my steering to the left, but when its hitting bumps on the road i dont hear any? i checked the struts and the springs are perfectly set on the strut. hopefully someone has the same problem as mine.. thanks people
Old Jul 25, 2006 | 05:34 PM
badhabit90's Avatar
ewwwwwww check your bolts...
Old Jul 25, 2006 | 05:42 PM
kreionic's Avatar
I have the exact same problem. Its at very low speeds when I go over a speed bump and or turn the wheel when going over it but nothing at any higher speeds
Old Jul 25, 2006 | 05:44 PM
MondoBongo's Avatar
that's odd, i have the same symptoms coming from the front passenger side suspension of my car, but only when you make right turns.
mine is stock though. i have it in to mitsu several times and they have not yet been able to track down the problem. the only idea they had was that the spring keeps rotating around in the housing, but when they realigned the spring it didn't make a bit of difference.
Old Jul 25, 2006 | 05:48 PM
4-BNGR's Avatar
your spring is not seated properly and at full lock where your spring is not under load, as it would be when your car has greater down force at higher speed, the spring is spinning and popping out inside the housing assembly.
just crank on your strut housing bolts and hope it goes away with time. mine did...
Makos1610's Avatar
have same problem with my s-techs i checked all bolts and i've benn taking them out and putting them in about 6 times still same noise
Old Jul 25, 2006 | 07:39 PM
essjEVO's Avatar
actually i checked everything.. and its fine... i have a feeling its the top hats.. im thinking about changing them to pillow ball mounts... but dont want to spend the money if thats not the culprit of the problem. thanks for the feedback guys
Old Jul 25, 2006 | 07:40 PM
essjEVO's Avatar
strut housing bolts? which ones are they? the ones under the hood?
mr1444
May 22, 2014 03:02 PM
wicked white14
26
Oct 12, 2012 10:46 AM
npham455
May 8, 2012 09:18 AM
dsevo
May 19, 2009 07:01 PM
damstr
30
Jul 23, 2008 10:53 AM
