bump steer problems
Old Aug 10, 2006 | 01:28 PM
ST's Avatar
ST
Originally Posted by RallySport Direct
The Whiteline bumpsteer kits goes in the rear where the toe adjustment is done.
The the metal sleeve inside the bushing will not move. It has to be pressed in so the bushing will not allow it to move. You want it to go with the hole offset towards the ground(when installed) to decrease bump steer and up if you want to increase bumpsteer.
I run these on my personal car. The car seems very stable even when thrown onto the rumble strips.
Great feedback, defintely on my list of mods to come!
Old Aug 10, 2006 | 04:32 PM
Czubaka's Avatar
1. Take off arm being careful to not break oil seal on the joint.
What oil seal are you referring to? Any recommendations on how to separate this joint? Thanks!
Old Aug 10, 2006 | 04:34 PM
RallySport Direct's Avatar
Silver Sponsor
The ball joint on the end of the arm if you use a pickle fork it will most of the time break the seal around the grease.
I recommend a puller be used instead of a pickle fork
Old Aug 10, 2006 | 04:36 PM
Czubaka's Avatar
Thanks!
Now, does anyone have the bumpsteer kit in stock?
Old Aug 10, 2006 | 04:39 PM
Silver Sponsor
I have a order coming in very soon that should have a bunch of them on there. I will pm you tomorrow and let you know when I will be able to ship it out.
Ben
Old Aug 10, 2006 | 04:44 PM
hotrod2448's Avatar
Has anyone actually mapped the bump steer characteristics of the Evo suspension?
IE:
Ride height =0
Compressed 1/2"= 1/16" out
Compressed 1"= 1/8'" out
so on...
I'm just curious how much it actually gains or looses.
Old Aug 10, 2006 | 05:20 PM
GTWORX.com's Avatar
Well stock, it should gain toe-in as the suspension compresses. I have not mapped it, but it certainly would be interesting.
- Andrew
Old Aug 10, 2006 | 06:17 PM
hotrod2448's Avatar
I've not really looked at the geometry. I have noticed some pretty "spooky" tendencies when the suspension compresses through a corner occasionally. At first I just thought it was either road undulations/ imperfections upsetting the car or crap rolling around the trunk and but, now that I'm thinking about it I sure it's was the bump steer I'm feeling. Maybe I should fix that.
EvoLemsy
Feb 8, 2013 12:34 PM
EvoTech
Apr 24, 2007 12:59 PM
indian_evo9mr
Apr 6, 2007 11:54 PM
x838nwy
14
Jul 9, 2006 01:23 AM
EVO MR FU
Jul 27, 2005 02:53 PM
