Optimum tire pressure
Old Sep 22, 2006 | 06:05 PM
JuancaROD's Avatar
I just replaced my wheels so I have a question for the experts, what's the optimum tire pressure for Falken Azenis RT-615 in 245/40-18? I'm riding on stock suspension on a 2005 Evo VIII SSL (in case it matters).
Thanks.
Old Sep 22, 2006 | 06:32 PM
EVOIXMR8916's Avatar
35-42 psi play with it....
Old Sep 22, 2006 | 06:33 PM
42= max ful economy i thnk 35ish is max contact patch...
Old Sep 22, 2006 | 06:42 PM
Smike's Avatar
Man, that kid is still on here...."play with it"...thats just rude....and he doesnt even have an Evo...
PM/Email/Call Neal@tirerack or any of those guys/gals at tirerack.
Old Sep 22, 2006 | 06:47 PM
f-dub's Avatar
Uh huh. Actually lowering PSI creates more contact patch. So 35 psi wouldn't be "max contact patch". 34 would give more, and 33 even more, etc. Look at how much contact patch you get out of a flat tire
Old Sep 22, 2006 | 06:54 PM
Smike's Avatar
lol...f-dub +1
And go in 2 psi steps, or you could stretch the tire too quickly (from my roommate - works for a national tire store)....he doesnt know about presure...he'd have to check tomorrow.
Old Sep 22, 2006 | 08:37 PM
Danny23's Avatar
the factory recomends 32 fr 29 r, i run 35 fr and 32 r in my IX and ran the same pressure in my 03 8. I find that to be the best for everyday driving,but like it was stated you have to play with it a lttle to see what feels right for you.
Old Sep 22, 2006 | 08:48 PM
Dus10's Avatar
After doing my own testing using a Pyrometer on all 4 tires (Falken RT-615's 245/45/17) I came up with 37 Front 33 Rear for cold pressure. These were the pressures that gave me a center tire temp that was the average of the inside and outside temps. The stock pressures aren't enough for these RT's, the outside & inside temps are always higher than the center with the stock recommended pressures.
Old Sep 23, 2006 | 01:59 AM
JDMevoBOOST's Avatar
I do believe Falken has a chart that lists all the cars and pressures for street/track with stock tire/rim size
Old Sep 23, 2006 | 05:36 AM
man you guys are idiots didt they tech this to you guys in drivers ed....they did for me wheh your starting to go lower the middle of the tire starts to raise and there is almost a airpocket there with no contact patch ill shouw you....
35psi...
..\_ _ _ _ _ _/
42-44psi...
.....\_ _ _ _/
25-30 psi
.\_ _ _- - -_ _ _/
and there you hae it drivers ed 101..lol just messing i just happened to learn this in drivers ed...
Old Sep 23, 2006 | 05:49 AM
DCSilvrEvo's Avatar
My stock tire pressure make the middle of the front tires wear faster meaning.... Over inflated!
Old Sep 23, 2006 | 06:16 AM
JuancaROD's Avatar
The problem here is that we're trying to make an aftermarket tire to handle as close to the stock Advan as possible. Now if Advans where a little bit cheaper the story would be different.
I'm running the recommended tire pressure on my RT-615 and the steering response is not close to stock in any way, so I think I need to up the pressure. There are plenty of people here running 245/40-18 RT-615s so I'm sure someone already found the optimum tire pressure. If this is happening on RT-615s which are known for having one of the stiffest sidewalls for our cars, I don't want to think how hard would be to calibrate other tires.
Old Sep 23, 2006 | 11:10 AM
JuancaROD's Avatar
Well, I've been playing with the tire pressure this morning and I have to admit it, no "affordable" tires will handle like Advans. Right now I'm at 41/37 front/rear and still the difference in steering response is noticeable. The tire states 50 PSI max., should I try more than 41 PSI?
Old Sep 24, 2006 | 08:27 AM
FJF's Avatar
FJF
i spent like 10 mins on that you ***
I find that very difficult to believe, unless you decided to finally show some respect for the reader by using your shift key where appropriate and delineating the text.
Old Sep 25, 2006 | 10:34 AM
Smike's Avatar
who ****in deleted my post ...panzy *** *****...i spent like 10 mins on that you ***
....They are called moderators. Show respect.
JohnBradley
Aug 15, 2013 08:52 PM
steinvb12
May 12, 2010 01:58 PM
drop24
Dec 8, 2008 06:26 AM
turboj
Aug 13, 2006 01:52 PM
