Wheel and Spacer question
Im looking at getting a good deal on a set of 17" gram lights. How ever the offset is +40 and they hit the Brakes......... what spacer do I need to clear these and will I be ok sence im dropped (dont want alot of rubbing)
Please help,
thanks
Please help,
thanks
it's going to vary depending on the spoke design. if you post up which gramlights (and what width) you're looking at and what tire size you're trying to use, maybe someone could help. best bet is to just take out a ruler though.
well in that case i guess just to make sure you dont rub run the 10mm spacer. How low are you dropped? I think you'll possibly rub on the inside for your fender. It just depends on what setup you're running.
Yeah I say run the 10mm. If you were to run 15mm it would be more flush, but just to make sure you dont rub i would say run 10mm. We usually run 245-40-18 for evo's and no matter how low the car is dropped we really dont see rubbing issues. If you want, take a look at our wheels @ www.ssixproject.com. We have an exclusive fitment for EVO's.
Ok here is what I got, I did a 7mm spacer in front and nothing in the rear. I used my stock lugs but im thinking i need diffrent lugs cause those washers on the OEM lugs are not in contact with the wheels.
Also I was only able to get 4 1/2 to 5 turns on the lug do i need longer studs? and will I be safe till I order them and get them in?
Thanks
Thanks
Originally Posted by SSIXProject
4 turns should be good. If you want full contact I would say to try and fine tuner style cone seat lug-nut set.
RedEvoxGSR
23
Jul 23, 2012 01:18 PM
mitsuevodriver
May 8, 2010 08:55 PM
