Spacers safe to run?
as long as it is the bolt on ones as mentioned earlier you are safe. i would not run anything else for strain on stock studs (the ones that are just a disc then you can hardly put your lugs on, stay away from).
Same here. Spacers are perfectly fine for auto-x/track use, provided you are being smart with them. The best way to do it is to get extended studs and use a slip-on hubcentric spacer. Stay away from the bolt-on ones since not every wheel will clear the stock studs that protrude from them.
