Stock Height Settings ???
Old Oct 6, 2006 | 12:41 PM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Anyone have the stock height settings? I was comparing some reccomended settings from different suspension manufactures and they are usually like -2.5 ect .... so that from the stock settings. However I dont remember the stock height settings.
Thanks for any help!
Old Oct 6, 2006 | 01:10 PM
johannes's Avatar
I ran in to the same problem and had a friend measure the height. Just under 15 1/4" in the front and just under 14 1/4" in the rear (center of the hub to the fender lip).
Old Oct 6, 2006 | 01:28 PM
M3this's Avatar
Nice! Thanks for the help
Old Oct 6, 2006 | 01:32 PM
johannes's Avatar
FYI-I've had pretty good luck at the track lowering about 1 1/4" front and rear with 10K springs up front and 12K in the rear.
Old Oct 6, 2006 | 02:04 PM
evoracerx's Avatar
Fender to wheel center line is
F - 385 mm
R - 355 mm
Set at 350 mm F, 330 mm R. Put a rear sway bar on, and run 2 kg higher spring rate in the rear front for a very neutral track set-up. If you are autocrossing you may want stiffer rear springs.
healthynine
11
Dec 8, 2011 03:55 PM
RTW EVO
Aug 16, 2009 03:14 AM
Solo Evo
Jan 28, 2008 07:14 AM
19psi
Apr 12, 2007 01:29 PM
gvr4v
16
May 17, 2003 04:21 AM
