help on offset?
help on offset?
What is the highest offset for 18'' wheels that fit on the Evo? I wanted to get some 18 inch wheels and they have a +45 offset.
thanks for the help
thanks for the help
Well that kinda depends on how much work u want to do. +45 is more of a honda offset you are going to want to go with +35 at least. Not sure if +45 will clear the brakes, but spoke design also plays into it.
So more importantly, what wheels are you trying to put on, then tell us how much work you are willing to do (fender rolling/flares) then we can help you. As of now it is too broad of a question to answer accurately.
Offset is based on the center of the wheel. Without knowing the wheel width, no one can answer that question.
18x7 ... +45 is ok (aside from the fact that your car will look stupid and handle like ****)
18x8 ... +45 is NOT ok (will probably rub suspension) But a 5-6mm spacer will make it ok
18x9 ... +45 is NOT ok (will definitely rub suspension) Need a 12-15mm spacer
Originally Posted by JDMevoBOOST
Oh and dont run any spacer if you can avoid it. I'd rather have a proper fitting wheel to begin with, but if u dont care then whatever.
jeff.thun
Jan 18, 2016 03:23 PM
thatguy5
Nov 1, 2011 08:18 PM
EVOlution33
Jul 16, 2008 04:25 PM
NocturnalEVO
24
Jul 29, 2005 06:54 AM
