Spring install question... do i need a special tool?
Old Nov 29, 2006 | 10:25 PM
twinturbozs's Avatar
I was reading the link for the spring install.
http://evomoto.com/tech_info.php?tPa...1258e894701047
It states not to use an impact gun to remove the top nut on the strut mount. Do all you guys have that special tool that allows you to remove the nut while holding it with another wrench? Ive changed shocks before on other cars, but ive always used an impact gun to remove the nut. Some expert opinions would be greatly appreciated before i tackle this job.
Old Nov 29, 2006 | 10:32 PM
Ultimate CC's Avatar
i have done several and i used an impact gun each time with no issues...
Old Nov 29, 2006 | 10:34 PM
thisxguy's Avatar
no impact gun...i remember reading that its NOT good to use them for this job
a spring compressor would be useful
Old Nov 30, 2006 | 12:45 AM
Soundave's Avatar
A spring compressor is a must, along with the right set of wrenches. I would stay away from using anything that doesn't let you control the amount of force (like an impact gun).
Old Nov 30, 2006 | 08:35 AM
evo150's Avatar
while the spring and shock is still installed in the car you just loosen the top nut 1-2 turns. you fully remove it after you compress the springs. but i am no expert. i followed evomoto.com install guide when doing my springs and have no issues. my 2c.
Old Nov 30, 2006 | 08:38 AM
sammyKiller's Avatar
Right on point. If you listen the top nut before you remove the strut assembly, it makes things much more easier.
Old Nov 30, 2006 | 09:57 AM
So all you guys have that deep socket wrench for the top strut nut?
Old Nov 30, 2006 | 11:50 PM
evo150's Avatar
its what i used. if you dont have one, they are about $5 at your local parts store
Kreeker
Jul 25, 2009 12:08 PM
tsitalon1
32
Mar 31, 2008 09:28 PM
ohthree
20
Apr 26, 2007 03:24 PM
az_evo_mr
Feb 10, 2007 10:28 PM
ralliartevolll
Dec 12, 2006 02:37 PM
