Front suspension noise?
Old Dec 20, 2006 | 08:29 AM
eve-slow's Avatar
My EVO is making a strange noise when I turn at low speeds and its coming somewherefrom the front. I am sure it is suspension related and am thinking its my endlinks. When it started, I jacked up the car and yanked on my sway bar to see if there was going to be alot of play and turned out there was only a little. This is normal right?
The noise actaully started coming from the drivers side, then went away for a little while and came back on the passenger side. So, it is probably somthing linking the sides (sway bar, end links, etc...).
I have buddy Clubs Race coils and stock sway and links. Does anyone know if there is a weak spot up there I should look for? BTW, this started happening shortly after my weekend at Road America. Thanks.
I really can't tell you exactly what the noise sounds like, best described as squeeking or light rubbing.
Old Dec 20, 2006 | 08:37 AM
Justindc2's Avatar
it happened to me too...its probably the cold.
whenever u turn u hear like a loud scraping noise right??
sounds like something screeching on the rotor but i dont know what it is
but this morning it was okay...it happened yesterady
Old Dec 20, 2006 | 09:19 AM
eve-slow's Avatar
Its not the rotors, but I do know what you are talking about. That happened to me in the past as well.
Old Dec 20, 2006 | 09:26 AM
Tsurugi-san's Avatar
Could it be a damaged rubber suspension bushing? Wouldn't that cause a bit of squeaking under articulating/turning load? I've got a similar situation with my stock Bilstein/RIDE springs setup --- I just assumed I damaged one of my control arm bushings by not waiting until the car was on the ground to torque it up. I have since purchased the urethane bushing kit and will have those installed with a set of coilovers next time around.
Curious, though.
purpledranktown
Jan 6, 2016 07:19 PM
powerman00
Jul 21, 2014 01:44 PM
Outie11
Outlander Sport
12
Jan 17, 2014 10:23 PM
Miller_x
Apr 12, 2012 03:41 PM
Nasty Evolution
Nov 6, 2011 09:34 AM
