Maximizing Handling of stock suspension....
Subscribe
Dec 20, 2006 | 10:19 PM
On my 05 EVO 8 the only suspension/handling mods are the OEM IX MR Bilsteins on OEM springs, Hotchkiss Rear swaybar (set full stiff), EVO RS rear trunkbar, Trailing arm bushings, and rear differential carrier bushings.....
I will get an alignment soon and set the toe at 0 all around, -2 camber in F, and -1 in the rear.....
Should I even bother with upgrading the bushings in the front and rear control arms also???
what about the front sway bar bushings? upgrade or leave alone?
Reply 0
Dec 20, 2006 | 11:24 PM
Rear control arm bushings makes the rear of my car feel solid bigtime. Zero "slush"
Reply 0
Dec 21, 2006 | 07:47 AM
Whiteline trailing arm bushings and rear bumpsteer kit are definitely worth it.
Don't worry about the front sway bushings too much. Get the Whiteline ball joint extenders though....
- Andrew
Reply 0
Dec 21, 2006 | 10:10 AM
Thanks for the responses....
my goal is to keep the stock height on my IX MR bilsteins and OEM springs
Reply 0
Dec 21, 2006 | 10:14 AM
Do you have camber plates?
The stock mounts wont let you go to -2 in the front unless you oval out the bolt holes a little bit.
Reply 0
Dec 21, 2006 | 10:19 AM
no I dont have camber plates and dont plan on getting them
Reply 0
Subscribe
