is an alignment needed for wheel/tire swap?
Old Dec 26, 2006 | 07:00 PM
hondafan's Avatar
Question is an alignment needed for wheel/tire swap?
hey guys(and gals ), i'm an avid wrencher but not much of a suspension guru. so my question is if i get an alignment now with stock wheel/tire combo, then swap on 18x8.5 w/235/40/18's, do i need another alignment and vice versa? the dealer told me yes, but i wasn't convinced. that would mean if you run a different size tire/wheel combo at the track your alignment would be off, correct? any help with this question would be appreciated and thanks for your time.
Old Dec 26, 2006 | 07:20 PM
hondafan's Avatar
c'mon, someones gotta know this! suspension guru's, where you at?
Old Dec 26, 2006 | 07:24 PM
Slowride's Avatar
If the diameter of the new tire is close to the previous set, you don't need an alignment. And, yes, an alignment will only be correct for a small range of tire diameters, so if your street and track tires are dramatically different, your alignment will probably be a compromise.
Old Dec 26, 2006 | 07:32 PM
hondafan's Avatar
going from 235/45/17 to 235/40/18. they're pretty close, so i should be OK then?
Old Dec 26, 2006 | 07:50 PM
Slowride's Avatar
Yeah, no problem. According to http://www.miata.net/garage/tirecalc.html, the diameter is a tenth of an inch different:
Old Dec 26, 2006 | 10:02 PM
hondafan's Avatar
cool. thanks for the link to that calculator too, very helpful.
BTBean
Outlander Sport
32
Nov 20, 2014 03:46 PM
romogst
May 29, 2014 12:40 PM
turbo50mike
Jul 24, 2013 06:56 PM
superalf574
Lancer Troubleshooting
Jul 5, 2006 08:25 PM
newmr
Jun 11, 2005 11:58 PM
