help need new pads
Old Feb 26, 2007 | 07:19 AM
deadbeatrec's Avatar
help need new pads
ok so hawk are good but what about Project mu? also might do some new front rotors, any sugestions? i found the sloted brembos for like 382 and the sloted mu's for like 426.
i need sugestions on pads and front rotors. i dont autox or road race so no need for anything serious. thanks.
ps, i drive spirtly like most evo owners so i want a good pad.
Old Feb 26, 2007 | 07:42 AM
20psiMR's Avatar
From what ive read the ferodo ds2500's are a great street/light track pad. Ive heard just way too many squeeling hawk stories that I think Im going to stay away. My brake upgrade will consists of 2piece rotors (PFC, or the stoptechs if they come out) with ds2500's.
Old Feb 26, 2007 | 07:50 AM
TxEvo8's Avatar
The Hawk HPS or Ferodo 2500s are good dd pads. If you use grease on the backs and edges, you should not have any squeeling issues. (Ive had both of these on my car) There should not be any reason to change out rotors if you are not tracking your car, I still have my stockers after 65k miles and several track days...
Old Feb 26, 2007 | 08:45 AM
what about project mu pads?
Old Feb 26, 2007 | 11:13 AM
a lot of reviews from tirerack.com say that the Hawks make a lot of noise.
Old Feb 26, 2007 | 11:28 AM
lords3t's Avatar
+1
if you're not even hitting track regularly, I don't think there is a reason to be putting that kind of money in rotors. You'd be better off spending that money elsewhere. And as TxEvo8 said, even with light tracking, unless you charge that corner and slam the ABS before entering a curve (and I mean make the rotors glow ) then you're fine. The biggest advantages of upgraded rotors is aerodynamics (cooling) and surface area. Doesn't sound like you need them. As for pads... I'd go with the Ferodo, I know it's already been said that you don't necessarily have to get the squeals out of the Hawks, but I wouldn't chance it either. There has been way too many anti Hawks complaints.
Old Feb 26, 2007 | 11:31 AM
evocanival's Avatar
I have the project mu, and they are great. no noise under normal driving. The ones the i have are the B-force.
Old Feb 26, 2007 | 11:37 AM
i think i want to try them. i found them for like little over $100 for the fronts and like $85 for the rears.
Old Feb 26, 2007 | 01:53 PM
DaWorstPlaya's Avatar
If you are only doing some regular daily driving and occassional spirited runs there is no need for Ferodo DS2500s. You are probably better off with Hawk HPS or Carbotech Bobcats. You'll save yourself some money in the process. You could also save yourself a lot of money buying cheaper 1 piece slotted rotors as you do not track your car. Just make sure you re-use the shims and bed in your brakes to avoid any squeeling.
