replacing camber plates
Guys,
Already did a search so I'm going to ask. I have the stock hat sitting on my KW Variant 3's (don't ask why, Germany is a funny country). To make a long story short, I want to replace the stockers with my Cusco camber plates. I think I may already know the answer but does replacing camber plates only require an new alignment?
Capt K
Capt K
The stock "flat" spring retainer on the KW's was design to be used with the stock top hats. If you go with a camber plate, youll need a tappered spring perch or else there will be contact. Youll need the 14mm tapered retainer; you can find them here. And yes you will also need an alignment.
Aby@MIL.SPEC
15
Apr 10, 2018 05:12 PM
spitefire1
Nov 5, 2015 07:44 PM
EndlessRed
Jun 18, 2013 06:08 AM
xtnct
22
Feb 24, 2008 09:45 PM
