100 lb enough ???
100 lb enough ???
is 100 ft lb enough tourque to tighten the lugnuts on the rims? For referance I have aftermarket volk rims. I tightened it to 100 ft. lbs, hopefully I didn't forget to tighten any !!! -.-
ahhhhh **** !!!!!! -.- so aside from maybe i stretched the threading on the bolts, is there anything bad that can happen while i drive??? btw, these aren't normal lug nuts, i have the rays extended ones.
Did you use a torque wrech or impact wrench. If you used an impact wrench you should be fine but if you used a torque wrench you MAY have stretched them abit. That being said, the lugs are very strong and your probably fine.
i Trq my lugnuts to 92ft/lbs & have been for almost 3 years now with no problems, i doubt another 8ft/lbs will stretch the studs. im using OEM lugs on the stock rims & Ray's lugs on the track wheels
according to the torque specs thread it lists 73 +/-7 ft lbs. I only torque mine to 73.
https://www.evolutionm.net/forums/sh...d.php?t=222551
100 ft-lbs is too much, but you won't damage anything short term.
Next time you get a chance, loosen them and re-torque them to around 75-80 and you'll be fine. My dealership torques mine to about 140 every time I go in there, and I have to re-do it no matter how many times I ask. I guess they are afraid my wheels might fall off!
