Toyo RA1 Alignment Question
I had stock size RA1s on stock wheels with -3 camber. The inner shoulder was nearly gone in about 2K miles. That's way too much camber for street driving with an R compound tire. If you drive for any amount of time on the highway the inside edge of the tire will be so hot that it will almost burn you, while the outside edge will be just warm. Toyo's camber recommendations are for competition use.
Also, my experience switching from Advans to RA1s was that grip was much better with the RA1s, but turn in response was much worse. When I saw that I was burning out my RA1s on the street, I dialed back the alignment and got PS2s for the street. They feel similar to the RA1s but with less ultimate grip (much better ride than the Advans though).
Dependant on use, but also remember that the Proxes RA-1 is a 100 UTQG, DOT-R compound tire. The RT-615 is not, rather it's more of a street / autocross tire with a 200 UTQG rating.
GetFoxed
May 28, 2014 04:19 PM
triguy
14
Dec 29, 2008 03:27 PM
STi2EvoX
17
Nov 24, 2008 02:55 AM
I will try again soon
