Wheel offset/spacer opinion needed.
Old Mar 26, 2007 | 09:50 AM
kaonashi's Avatar
Alright I am considering to buy my friends rims off of his STI, he said his offset is +42, and i believe evo max is +38 They are 17x7 basically same as stock just larger offset. What i am wanting to know is if i could get away with out a spacer or which size spacer i would end up needing to get and if i need longer studs.
His rims are
Volk Racing LE28n's
17x7 +42
Tires 235/45/17
And i was considering getting Tein s-tech also
Old Mar 26, 2007 | 10:36 AM
kaonashi's Avatar
bump need to know what i should do before i buy his rims
Old Mar 26, 2007 | 12:41 PM
kaonashi's Avatar
no one has an opinion?
Old Mar 26, 2007 | 02:02 PM
TVA's Avatar
TVA
My opinion is don't buy them. At that offset they likely won't clear the caliper and they are more narrow than stock (which is 17x8) If you absolutely have your heart set on them you'll need an 8mm spacer or so and extended studs. I assume that his STi is an 05+? If not they are the wrong bolt pattern anyway.
Old Mar 26, 2007 | 03:29 PM
kaonashi's Avatar
yeah his is new doesnt look the same as the old suby's i geuss i wont get them, to much to worry about, ill just tell him ill have to find something else
Old Mar 26, 2007 | 05:28 PM
jbrown's Avatar
Good idea to skip it. It would have been a rig at best, and the end result would be a rim that is too narrow anyway. Stock is 17x8
By the way, you would have needed a minimum 17mm spacer just to make it sit in the same place as the stock wheels. (13mm for 1/2 of the 1" width difference and 4mm for the offset difference)
JasonByeon
May 10, 2016 09:35 AM
FL_SilverEvo8
Oct 4, 2013 10:25 PM
FL_SilverEvo8
Oct 4, 2013 10:22 PM
mcm308
Jun 11, 2011 07:15 AM
nubi4life
Jan 28, 2010 10:01 AM
