Wheel Fitment PICTURES ONLY Thread
Old Oct 12, 2015, 06:49 PM
  #301
azboost92's Avatar
Originally Posted by bboypuertoroc
Wheels: Enkei RPF1, 18x10 +38
Spacers: 20mm spacers up front, 5mm spacers in rear
Tires: Bridgestone RE050, 265/35/18
Suspension: Stance Coilovers
Fender work: removed front fender liners
Barely rubs at full lock at the inner most part of where the end of the side skirts sit inside the front wheel wells. Trying to fix.
RPF1 look so damn good. Would love to get a set!
Old Nov 17, 2015, 11:08 AM
  #302
cts4g63's Avatar
Originally Posted by gocchin
ADVAN RSII Semi Gloss Black 18 x 9.0 +35
Direzza 245/40/18
Such dreamy wheels.
Used to run Rota GForces 18x9 +30 on my B5.
Old Nov 20, 2015, 04:35 PM
  #303
kayyevo's Avatar
ENKEI RPF1 18 x 9.5 +15
Bridgestone Potenza RE002 245/40 R18
Old Dec 15, 2015, 07:19 AM
  #304
AdyEvo4's Avatar
OZ Superleggera 17x8 et35 & 8mm spacers to fit on Brembo with 215/45R17, slight rub (splash shields)
Tecnomagnesio TM Sport 17x7 ET38 w/o Brembo
OEM Evo6 17x7,5 et38 - best fit on E4 with Brembo
kraven9 (Feb 19, 2017)
Old Jan 13, 2016, 05:17 AM
  #305
helios-73's Avatar
Wheels: ADVAN RSII SEMI GLOSS BLACK - 18x8,5 ET31
Tires: ADVAN NEOVA AD08R, 235/40/18
Suspension: OHLINS R&T
No fender work
Old Mar 26, 2016, 10:35 PM
  #306
Hunter Cimini's Avatar
Originally Posted by phizzalot
Cosmis Racing MR2
18x9.5 +15 Rear, +5 Front 10mm spacer
245/40/18
Rear Rolled/ Front max negative camber via bolts.
RSR TI Lowering Springs.
needs liner heat mod.
Lots of brake dust from ebc reds . But they do what there suppose to
beautiful
Old Apr 2, 2016, 03:30 PM
  #307
Grimgrak's Avatar
Does anyone still sell a front fender spacer kit?
Old Apr 2, 2016, 03:49 PM
  #308
Received 1,384 Likes on 1,317 Posts
Most are making it themselves here:
https://www.evolutionm.net/forums/ev...der-mod-2.html
Old May 8, 2016, 10:00 PM
  #309
BrownSuga's Avatar
Advan RG-D 17x9 +29
245/45/17 Brigdestone RE71-R
Bilstein HD struts with Espelir springs
No fender mods, minor rub on the inner part of fender liner at full lock.
Old May 9, 2016, 12:36 PM
  #310
Originally Posted by BrownSuga
Advan RG-D 17x9 +29
Looks great. I run a similar wheel RGII 17x9 +29. Would have recommend the following:
255/40/17 & a fender roll
Old May 9, 2016, 10:46 PM
  #311
BrownSuga's Avatar
Wanted 255/40, but they were out of stock on them in the RE71-R. They weren't going to get stock for awhile, so settled for 245/45
Old Jul 26, 2016, 01:12 PM
  #312
alsxe10's Avatar
is anyone running 17x9 +18 square?
if so any pics?
Old Jul 26, 2016, 01:42 PM
  #313
if so any pics?
Tough to get someone who maybe running this spec to see this post. The +18 would very difficult to fit correctly in the rear. Up front you can make work w/out too much trouble.
Would need a very tight rear roll w/a fender pull, plus the bumper bolt relocate to make this work
Its doable but not recommended
Old Jul 26, 2016, 02:06 PM
  #314
huzzle101's Avatar
Dunno why but this is still my all time favourite EVO, used to drool about them back home.
Old Oct 3, 2016, 03:02 PM
  #315
Akorallygood's Avatar
18x10.5 +22 10mm wheel spacer in front 245/35/18
Fortune auto coilovers
Front rolled
Rear rolled and pulled
Camber -2.5 front -3.5 rear
Quick Reply: Wheel Fitment PICTURES ONLY Thread
