Camber kit
Old Apr 27, 2007 | 08:50 AM
Crz10's Avatar
Camber kit
Hey guys i am trying to find a rear camber kit for my evo 8 can't find it i did find the front camber kit . Just wanted to know it anybody knows where i can find the
rear camber kit. Thank you
Old Apr 27, 2007 | 08:55 AM
tsi90awd's Avatar
You probably don't need a camber kit. The rear suspension settings are adjustable using the stock components.
Old Apr 27, 2007 | 09:09 AM
Crz10's Avatar
camber kit
I got aftermarket springs on my car and my aliment is way off and my tires went bad. i got the front camber kit on . so you are saying i am fine with out the back camber kit.
Old Apr 27, 2007 | 09:13 AM
tsi90awd's Avatar
I don't know what you mean about a front camber kit. That is adjustable within limits as well. The only "camber kit" you can get for the front are top camber adjustment plates. There is nothing needed or available, afaik, for the rear. i used lowering springs for a few years and the stock adjustment bolts were fine for getting decent settings for the front and back. Unless you want camber at the front more than -1.5 degrees, you don't need anything else.
Old Apr 27, 2007 | 09:14 AM
tsi90awd's Avatar
Ah. Just reread your post. Your tires probably went bad because you didn't get a re-alignment after installing the springs. That will do it!
Old Apr 27, 2007 | 09:17 AM
cfdfireman1's Avatar
Don't need a "kit" just get it aligned right.
Old Apr 27, 2007 | 09:22 AM
Crz10's Avatar
camber kit
you are right i did't get my aliment done after i got the springs done i guess
thats what i did wrong. so i should be fine with my stock aljustments
Old Apr 27, 2007 | 09:24 AM
meckert's Avatar
The tires wore because of the toe adj....has nothing to do with the camber of the tire...adj the toe back to specs (0..if you want to be certain)...check camber is the same of both sides or put it where you want it...
Old Apr 27, 2007 | 09:27 AM
BoostEEd's Avatar
um. yeah. Anytime you alter ride hight or change suspension components you should have it aligned.
Old Apr 27, 2007 | 09:36 AM
Crz10's Avatar
camber kit
Thank you guys i guess i learned my listen the hard way.
Old Apr 27, 2007 | 10:36 PM
Turbo-d's Avatar
There are always many things to learn
Old Apr 28, 2007 | 05:22 AM
BoostEEd's Avatar
Isn't that the truth
Old Apr 29, 2007 | 02:36 PM
EvImVictim's Avatar
I think someone also makes a better adj. bolt than the stock one for camber. Stock one is notched and will only do -1.5 & -2 deg. Aftermarket one is variable between the settings.
Old Apr 29, 2007 | 02:39 PM
EvImVictim's Avatar
Yeah, true dat.
Alignment was out on mine (toe) straight from the dealership. Cost me a pair of tires to learn that too.
mitsuevodriver
19
Jan 17, 2016 08:37 AM
zbents
Dec 4, 2013 01:20 PM
RedStarr
Aug 10, 2011 11:11 AM
Jake26
MitsubishiParts.net - WA
Feb 5, 2011 07:29 AM
evil03
Jan 26, 2010 10:34 AM
