Tein Type Flex
Old May 2, 2007 | 01:14 AM
ferg900's Avatar
Tein Type Flex
how many clicks adjustments does this coil have? i try playing around with the front coils the other day. i turn anti-clockwise all the way n i manage to turn down 25 clicks.. is there something wrong? n wats the common setting for tein type flex?
Old May 2, 2007 | 02:12 AM
ChuckP's Avatar
Im pretty sure the type flex are 16 way adj. Some coils will continue to click farther. Your better off setting them back at 0 and count each turn. Dont exceed 16 or you will risk damage.
Old May 2, 2007 | 04:58 AM
ferg900's Avatar
holy ****.. i better go get it adjusted back... anyway just to confirm is anti-clockwise to 0 right? den clockwise to 16 clicks for hardest? same goes for the rear?
Old May 2, 2007 | 12:07 PM
ChuckP's Avatar
you are correct.
Old May 2, 2007 | 01:17 PM
anjapower's Avatar
turn clockwise all the way until it stops. You shouldn't turn anti clockwise more than 16 clicks.
Old May 7, 2007 | 01:28 PM
DanInPA's Avatar
Yes, that's normal. Like one suggested above, set it at 0 setting clock wise (Stiffest), then turn clicks counter clock wise. It will turn more than 16 clicks but would not recommend it as spring rate is 12/10.... I use 9 clicks from stiffest and it is good! Also, make sure to tighten the bottom ring to lock the strut/shock body (both front and rear) as it is not tightened from the factory. Also, don't forget to measure the strut/shock body height to Tein recommendation before locking (It's in the instruction)... This will save your as* off from any structure failure as well as strut/shock body rotating over the time... Tein instruction also has the recommended height setting for upper perch on spring setting which you can measure off the car.... I have raised 1/2 inch on the front and 1/4 inch in the back, higher than their recommended setting and car runs 100% better than stock MR suspension. Also, make sure to get alignment and corner balance if you have $... My alignment was very little off from factory spec....
This is the best mod for EVO in my opinion....
nuggetinu1
Mar 28, 2016 02:08 AM
resident
Feb 9, 2016 12:31 PM
Dragracer187
Aug 9, 2012 01:39 PM
the4thpower3
14
Feb 23, 2005 06:43 PM
ONIMUSHA
14
Aug 17, 2004 04:44 PM
